Old 13-08-2004, 12:50 PM   #1 (permalink)
Default can we upload music from tape recorder to pc?
guys,
can anyone suggest me a software to upload music from a tape recorder to a pc? please give me instructions or weblinks , how to do it.
i am using a 60 watt sony cfs1050s
ParadoX is offline
Old 13-08-2004, 01:32 PM   #2 (permalink)
MusicMatch Jukebox can record from the soundcard to mp3. Just connect the line-out of your tape player to the line-in of your comp and you are all set to start recording.
wORm is offline
Old 13-08-2004, 01:42 PM   #3 (permalink)
will he ablr to doit in a small 6o watt system? any answers?
girish_b is offline
Old 13-08-2004, 01:51 PM   #4 (permalink)
download Audiograbber v1.70 build 2 with this code
http://netvision.tucows.com/files/agsetup.exe
help
http://www.trustmeher.net/freeware/audio.htm
girish_b is offline
Old 13-08-2004, 01:54 PM   #5 (permalink)
mariner's Avatar
well digit gave the full procedure in one of their earlier issues dont remember which. y dont u look into the cd of june 03 which had all the previous issues in the digital format and u might b able to get the proper procedure
mariner is offline
Old 13-08-2004, 02:46 PM   #6 (permalink)
yeah all you need is to get that line in-line out cable. its a cable that has the (in laymans terms) earphone plug on both ends. . after that you can use any software (i prefer musicmatch jukebox) that supports sound recording, and just set the input to line-in recording.
hummerBLOG
visit mumbaikids.net now!
sohummisra is offline
Old 13-08-2004, 03:41 PM   #7 (permalink)
NikhilVerma's Avatar
i'll prefer sound forge as you can remove the noise and do other corrections after recording...
NikhilVerma is offline
Old 13-08-2004, 03:54 PM   #8 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Cool Edit Pro (now Adobe Audition) is well-suited to convert analog music into digital format (cassette to CD) .
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 13-08-2004, 06:39 PM   #9 (permalink)
Yeah line in-out to your tape and connected to your sound card with the other pin, you can use soundforge, Cool Edit, Musicmatch.. but i recommended cool edit, coz u can edit and make changs to the sound file easily!
Knowledge is power!
curvenger is offline
Old 13-08-2004, 07:48 PM   #10 (permalink)
ParadoX, I don't know what the "technical term" is for the cable, but if you tell an audio guy to get you a "single-to-double" cable, he'll get you a cable with a headphone size pin on one end and two standard auxillary pins on the other end. Also insist on a stereo cable and avoid the mono version.
girish_b, the wattage of the source (in this case 60 watts) doesn't matter, as we are transferring un-amplified sound. We can expect good quality reproduction of sound, provided that the source recording is good.
wORm is offline
Old 13-08-2004, 09:24 PM   #11 (permalink)
i prefer audio maestro by Tobest software. It has features similar to Audition, but it has an added cool feature i could'nt find in audition. It gives you a recording option where u can play the tape and leave it by itself, it will autodetect pauses between songs and start a new file accordingly. This saves you from clicking the 'stop' button every 3-4 minutes, or end up with a 1 gb file with nothing but garbage at the end.
but it will work smoothly if you have 256mb or more ram.
technomodel is offline
Old 13-08-2004, 11:54 PM   #12 (permalink)
But use this as your last resort, cuz the soubd quality isn't exactly that good. But still a good way of experimenting with audio and stuff.
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 14-08-2004, 02:13 AM   #13 (permalink)
Ashis's Avatar
Try CoolEdit Pro!
(Smart, Simple & Smooth) 8)
Ashis is offline
Old 14-08-2004, 01:00 PM   #14 (permalink)
link for downloading audio maestro trial
http://www.topshareware.com/Audio-Ma...nsfer-3823.htm
Old 14-08-2004, 04:18 PM   #15 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
I used Microsoft Plus! Digital Media Edition. The recording quality was top-notch !!
Flickr!
Kl@w-24 is offline
Old 14-08-2004, 04:58 PM   #16 (permalink)
EinSTeiN's Avatar
Use Jetaudio, it is the easiest option. even kids can use it. www.jetaudio.com
;) ~~EiNsTeIn~~ ;)
http://www.tejuspratap.co.cc
EinSTeiN is offline
Old 14-08-2004, 11:24 PM   #17 (permalink)
I WANT MORE FPS!!
adithyagenius's Avatar
What is that software & where did u get it
adithyagenius is offline
Old 15-08-2004, 11:39 AM   #18 (permalink)
don't worry if u can't find the cable!!
just go to your neighbourhood tv repair shop and buy 2 pins and wire to suit ur needs and tell him to solder it!! i got my 3 metre cable for rs 15!!
We are what and where we are because we have first imagined it...
--Donald Curtis
silly_kash is offline
Old 15-08-2004, 12:35 PM   #19 (permalink)
abhishekkulkarni's Avatar
There is no need to download any third party software.If you use Windows XP just by using Windows Movie Maker which is installed by default u can record audio from ur audio system in WMA Format.Connect the Headphone outlet of your player to the line in port of your soundcard by using a mala-male cable.The recording quality is great.you can select as high a bitrate as you like.
abhishekkulkarni is offline
Old 15-08-2004, 01:25 PM   #20 (permalink)
pantheratigris's Avatar
I first did this about 3 years ago. I had taken a walkman. Connected the line out jack(headphone socket) to the line in(mic) at the back of your PC cabinet. Then i played the songs on the walkman, recorded the songs on the sound recorder in windows. Then i saved it as a .wav file. Then using a software known as dBPowerAmp music converter i converted the files from .wav to .mp3. You can also use Windows Media Encoder to convert to .wma format which is as good as mp3.
Alcohol and Mathematics do not mix, Don't DRINK and DERIVE! ;)
pantheratigris is offline
Old 15-08-2004, 01:28 PM   #21 (permalink)
Howver youll need the RC cable. It consists of two small male pins at both ends. Make sure that it is stereo though. A stereo cable generally has two or more black bands on the pin. If you use a mono cable you wont get the other channel. So make sure you use a stereo cable and not the normal mono one.
Old 16-08-2004, 11:55 AM   #22 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Microsoft Plus! (DME) is a set of digital tools like 'Analog Recorder', 'Plus Dancer', WMP 9 skins, plugins for Windows Movie Maker 2, Sleep timer, CD label maker, party mode for WMP9 etc. I got it from the friendly neighbourhood CD-wallah
Flickr!
Kl@w-24 is offline
Old 06-08-2009, 04:31 PM   #23 (permalink)
paroh's Avatar
Default Re: can we upload music from tape recorder to pc?
i had once done this with trial version of acoustica spin it again software
***********For computer related Problem PM me (If want's Doeacc A Level Project PM Me )************
paroh is offline
