29-04-2007, 03:54 PM
Back to l33ching :)
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
Compressing an .iso image
hi people, how do i compress an iso file? winzip cant, since it says it doesn't support file sizes so large. winrar cant, gives the error "cannot modify volume". it may sound stupid, but i need t know, coz when i try to write it to a dvd, it exceed the capacity. (am trying to write it as a data cd)
or if i try to write it from the image, will it work? also any freeware,simple iso editor around?
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
29-04-2007, 04:45 PM
Mad and Furious
Re: Compressing an .iso image
U must burn the image to the disk.
Compressing it will not help if the size of the image is larger than that of your disk.
29-04-2007, 05:07 PM
ToTheBeatOfUrHeart
Well i have compressed dual layer xbox 360 games with winrar how come u can't??
29-04-2007, 06:07 PM
WinRar does support large files ....
and also try using 7zip from 7-zip.org, compression ratio 2-10 % and its a freeware..
Be like a postage stamp-stick to one thing until you get there.
29-04-2007, 10:15 PM
Use ISO buster..
Do or Die
http://www.hamrobrt.com/howto-install-flash-player-in-ipad/
29-04-2007, 10:48 PM
NP : Crysis
hey i comfortably compress dvd iso images using winrar though the size difference is negligible. i guess an iso image isn't very good at getting compressed
29-04-2007, 11:30 PM
Back to l33ching :)
well, actually its a game iso. i have tried with winrar, but it gives the error "cannot modify volume". any workaround for this?
30-04-2007, 11:00 AM
C# Be Sharp !
mean what do ya wanna do , simply the burn the ISO on the required media man ,
i think you're trying to compress the iso an save it as the normal file onto a CD/DVD , well i think that wouldn't be possible coz ISO contains a lot of metadata and filesystem info so that wouldn't fit onto the media if you try to write it as a normal file , just write the ISO sirectly using Alcohol 120% or ISObuster
There are 10 types of people in the world: those who understand binary and those who do not.
30-04-2007, 11:02 AM
ToTheBeatOfUrHeart
U can select the option to split the archive into sizes of 100mb each and that way u can possibly compress the iso file.
30-04-2007, 11:41 AM
C# Be Sharp !
well u'll achieve very futile compression ratios so it's better you don't try to compress it , if the image is larger than hte media n u really do want to write it as normal data then put it into a winrar archive , select the compression type to "store" n then select part siez that uwant the image to be splitted into , this way u can write hte image as normal data .
30-04-2007, 08:48 PM
Back to l33ching :)
thnx guys n zeeshan too for the replies, i guess i'll write it as an image only, n not a data file. one more question tho, wich softie do i use to insert a file into the iso image, widout altering it in any way.
30-04-2007, 08:52 PM
C# Be Sharp !
well i use UltraISO to edit an image n it works perfectly
30-04-2007, 09:11 PM
The Researcher
Using Nero, write your ISO by using burn from image option. I think you may require a blank DVD for that.
30-04-2007, 09:19 PM
Back to l33ching :)
^ i dint want to do that, coz i has another file to go along with the iso file. but now that seems the only choice.
Search this Thread |
