Old 12-02-2005, 10:51 PM   #1 (permalink)
Default CONFIG SUGGESTION POSTS HERE PLS!
people who want opinions on their configs should post here for easier viewing and a cleaner thread.
thank you
supersaiyan is offline
Old 12-02-2005, 11:14 PM   #2 (permalink)
darklord's Avatar
i didnt get you
darklord is offline
Old 13-02-2005, 12:53 AM   #3 (permalink)
hes just trying to start a new thread for all configuration problems
like we have all gpu questiosn should go here sticky
besides this was tried out quite sometime back .. and scorned at quite a bit ....
i dun remember the username tho !!!
anyways ... ur luck ....
theraven is offline
Old 13-02-2005, 07:06 PM   #4 (permalink)
darklord's Avatar
Ok i have a query.
I have a Powersafe 500 Watt SMPS.It is not sufficient for my system and i wish to put my 350 Watt SMPS to use.In short i want to use 2 PSUs for same system,any solutions ?
darklord is offline
Old 13-02-2005, 09:09 PM   #5 (permalink)
Ethan_Hunt's Avatar
well now.....a new config thread being attempted to made sticky ehhhhh......what next a monitor or a hard disk thread...lol
well the attempt is good supersayain......will try to round up some newbies to ur thread......already there are couple of posts made for config's....hope they get the essence of ur thread and begin postin in....good luck
Ethan_Hunt is offline
Old 13-02-2005, 09:14 PM   #6 (permalink)
what the ?
lol
ok sure m8 ..
u cant connect the psus in parallel thats for sure
just mod the cabinet a bit so u can mount the second psu somewhere
and use individual plug points
thats all i can think of ....
ps : if u dun mind me askin
i know u have sli in workin mode
but how exactly is 500 w psu NOT enough for ur system ??
theraven is offline
Old 14-02-2005, 08:58 AM   #7 (permalink)
darklord's Avatar
Raven,
Your query is totally justified,infact i was surprised in the beginning too.
But the thing is the PSU available in india never supply the rated wattage.
Amngst the whole lot,powersafe is far better,agreed.
The main drawback of that PSU is that it offers only 18A on +12V rail,which is too low for a 500 Watt SMPS.It should atleast be 20-24 A.
Now according to Asus if you put 2 x 6800GT in SLI ,it is recommended to use an SMPS offering 20+ A on +12 V rail.
Here is my complete config,
AMD Athlon 64 3200+ [winchester]
Asus A8N SLI Deluxe mobo
1 GB DDR400 Transcend RAM
80 GB Hitachi HDD
200 GB Seagate Cuda HDD
Benq DW1610 DVD-RW
2 x XFX 6800 GT in SLi
Now looking at that config,there arent too many devices but still i get 11.7 or less on +12V rail,which is not good.
Also i experience frequent crashes,cold boot ups...
So i guess you can imagine what the scenario is now.
I have worked out a way for it,lets hope the experiment works.
Will let you know if it works.
darklord is offline
Old 14-02-2005, 10:17 AM   #8 (permalink)
u should have gone for antec
Old 14-02-2005, 10:40 AM   #9 (permalink)
darklord's Avatar
I didnt want to spend 8k when i had 2 PSUs with me
darklord is offline
Old 14-02-2005, 10:48 AM   #10 (permalink)
correct me if I am wrong, but I read somewhere that it isnt advisable to connect two PSU's in parallel ?? !
It " might" be possible to use two supplies, but not with them both connected to the same part of the load.
Using one for the motherboard, and the other for drives/fans etc may work, providing they are both connected to the case electrically. However, as most supplies need a minimum load on all rails, and the one powering drives would have no load on the 3.3V rail you may blow the supply! Switching the supplies would also be difficult, without using a relay to operate both at once.
Without experience of electronics construction it would be difficult, and probably more expensive that buying a larger supply in the first place.
And I am curious as to the kind of soultion u managed darklord.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 14-02-2005, 02:33 PM   #11 (permalink)
I am too waiting for which solution is working out for you Darklord.
Do let me know.
Your Config is absolutely fabulous gr8 choice.
quad master is offline
Old 14-02-2005, 03:33 PM   #12 (permalink)
darklord's Avatar
Ok here is what i did,
I took a 350 Watt SMPS,in the 20 Pin ATX mobo power connector,shorted the green and the black wire.
When you switch on ur PC theses 2 wires get shorted.
So when i shorted the two wires by a single core wire,as soon as i give power to the SMPS,it starts.
Now i connected the HDDs,DVD-RW & Fans on this PSU.
I Connected the 500 Watt PSU to the Mobo so it was giving power only to mobo,CPU,grafix cards,thats all.
Mind you i DID not short the 2 PSUs together.So it is as good as saying that HDDs and stuff get entirely external power.
Now i have connected this PSU alongwith the 500Watt to the UPS.
So when i start the UPS,the 350 Watt SMPS starts,starting the fans,HDD & DVD-RW get power.No i start my machine.Since HDD and DVD-RW have power from beginning,system works flawlessly.
I guess i ahve tried my best to explain it as simple as possible.
If you ahve any other query,please get back to me.
darklord is offline
