Old 26-04-2007, 02:30 PM   #1 (permalink)
GeekyBoy's Avatar
Default Torrents...
How can I configure my Huawei MT 841 for use with the Azeureus Torrent Client ?
GeekyBoy is offline
Old 26-04-2007, 03:31 PM   #2 (permalink)
Debian Rocks!
freebird's Avatar
Smile
there is a thread torrent HW2 @:
Torrenting for n00bs:
Torrenting For Dummies
"The day windows users wake up to reality, it will be doomsday for Microsoft."UNIX like OS are more secure.get urself out 4m M$ http://whylinuxisbetter.net http://tinyurl.com/2amjjc http://fsf.org
freebird is offline
Old 26-04-2007, 11:28 PM   #3 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Default Re: Torrents...
Haha,My post is being used atleast somewhere
rakeshishere is offline
Old 27-04-2007, 01:14 AM   #4 (permalink)
18 Till I Die............
http://www.portforward.com/english/r...41/Azureus.htm
http://www.bash.org/?258908
mehulved is offline
Old 27-04-2007, 01:32 AM   #5 (permalink)
well, i have the same router but Azureus works fine without doing anything... but the speeds are pathetic... should I also configure the router ?
bazigaar_no_1 is offline
Old 27-04-2007, 02:22 AM   #6 (permalink)
If you think that you dont get the mixum download speed which provided by your ISP then you should configure your router to make your azureus connectable to other client.
If you dial from your computer using RASPPOE provided by your BSNL then you dont need to configure your ADSL modem and if your ADSL modem it self using authentication to BSNL then you need to configure your ADSL modem to make your Azeureus connectible to other client in network to get better download speed.
Last edited by Indranil92001; 27-04-2007 at 02:22 AM. Reason: Automerged Doublepost
Indranil92001 is offline
Old 27-04-2007, 08:41 AM   #7 (permalink)
i get download speeds of about 60-70 kBps....
and upload speeds of about 10 kBps...
please suggest what should I do further..
What is Torrents? Gigacore QnA (read only) 7 18-04-2007 10:33 PM
Torrents ovr lan?? lionelxp Software Q&A 1 15-04-2007 03:35 AM
What are Torrents? //siddhartha// QnA (read only) 6 18-09-2005 09:57 AM
TORRENTS??????????? SHell QnA (read only) 3 16-11-2004 06:40 PM
