Old 26-04-2007, 12:34 PM   #1 (permalink)
56561's Avatar
Default CMOS battery
if my CMOS battery goes bad or becomes dead then what kind of problems may arise in my PC?
56561 is offline
Old 26-04-2007, 01:16 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: CMOS battery
The Clock will show Wrong Time plus it will revert the BIOS to factory default settings. The BIOS will have redect the hardware attached each time aswell
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 26-04-2007, 01:48 PM   #3 (permalink)
anilmail17's Avatar
u computer will turn into a hell.
evry time you will start your pc you have to set the date time first otherwise u will get certificate expire warning each time you will open a webpage.
you have to press a a key like F1 ignore bad CMOS checksum error.
All your BIOS otimised setting like disable floppyBoot seek up other setting will be reset.
huuh you must change the CMOS battery soon
visit my blog
www.anilsoni.wordpress.com:)
anilmail17 is offline
Old 26-04-2007, 09:38 PM   #4 (permalink)
piyush gupta's Avatar
Just got a new battery it cost 20-30 Rs
piyush gupta is offline
CMOS or CCD?? sagardani Hardware Q&A 4 29-01-2007 10:48 PM
CMOS battery replacement ashu888ashu888 QnA (read only) 4 26-10-2005 07:11 PM
CMOS problem mkpaul QnA (read only) 4 24-07-2005 12:23 AM
MB's CMOS battery discharge problem sms_solver QnA (read only) 3 12-11-2004 01:42 AM
