Old 12-02-2005, 11:23 AM   #1 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Default Noisy PC?
Firstly my PC Info
P4-2.4Ghz without HT
256MB DDR 400 RAM
80GB 7200rpm Seagatte Harddrive
Intel 845GVSR Motherboard with onboard 64MB AGP Memory
RealTek 97 Audio
Win XP with SP2
My PC makes a lot of noise when working. When I start it it does not make that much noise but after 2-3 minutes of booting up it makes a loud like that of a hair dryer and is so loud that it can be heard in the next room and is annoying if i work on it at night.
The noise may not be from the HDD because I recently changed my HDD and this noise problem was with the previous 20GB HDD also.
My PC Vendor does not think it as a serious problem and tells me that every 2.4GHz processor of Intel has a problem with the fan and all such processors make similar noise due to the defective fan. He also says that there is no use of replacing the original fan with a local one. Is the above statement true?
I even tried Motherboard Monitor Program but it does not support my Motherboard and i do not know how to change its settings according to my Motherboard.
A new thing which I have noticed that when I keep a wet cloth on the CPU cabinet the voice slows down.
But I can't bear such a loud voice. What should I do? Its getting noisier day by day.
-Navjot Singh
-navjotjsingh@gmail.com
navjotjsingh is offline
Old 12-02-2005, 11:34 AM   #2 (permalink)
why need title?
bharathbala2003's Avatar
hmm seems like ya system needs cooling.. try keepin da cpu in a well ventilated place.. and make sure the cabinet is airated.. then check if all the fans are in proper condition.. if ther is a small broken piece also this sound may come.. cos i had a one of the wing of my fan broken n the sound was BAD!!!! i replaced it n it went! dont bother to call ya hardware engg he wont have the patience to xplain much try gettin a gud fan.. else open up the cabinet covers n make sure u keep the proccessers cool
P.S in case u got a AC room try keepin da AC on for a while to cool the CPU down
bharathbala2003 is offline
Old 12-02-2005, 04:22 PM   #3 (permalink)
... check the level of the cabinet .. shud be on a flat surface!
check inside to make sure no cables r coming in contact with the fan....
Don't use wet cloth...can give u a shock if earthing is not proper!!
grinning_devil is offline
