hi..abhijangda n redhat,
Accutally Im creating a helpdesk for company..using
VB..its like operator enter machine malfunctions that occur in system(the page called as 'ticket')and then they send to technicians..and if technician couldnt solve the problem they have escalte the problem to engineers..technician also need to enter status(attend,finish,pending,wait,escalated) on the system. if they have solve the machine problem,operator need to decrypt system by closing the ticket.the current problems and status must appear infront (mainpage ) of the system so that every employees can view what are the problem occur on machines...this is the main process my system cover..if anything i can explain more..
Thanks
hi..
i got one prob, when I save the form that I have created, the design(mean the
vb form icon) of the form doesnt appear only the coding [form1.
vb and form1.designer] is appear... y ah? after i double click form1.
vb or form1.designer only the coding is appear...not the form1 interface that I create...u guyz have any idea..
FYI im using
VB 2005.. n microsoft SQL
Thanks
