am planning to buy a new dvd combo drive..... as my present one is getting weak..... now the thing is that i came across external dvd drives....which appeled me a lot... as i will be able to keep my old one ...conneted which still perform...... now what i want to know is there any performance difference between external drive and internal ...... and which one should i go for
People laugh Because Am Different. And I Laugh Because They Are All The Same......
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
Re: which one is better
external ones will be costlier, i don't recommend one if u plan to use it for ur system only, internal ones perform better anyway. digit had carried an article on them too, but dnt remember the edition
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
