LinkBack (4) Thread Tools Search this Thread Display Modes
Old 22-04-2007, 07:56 PM   4 links from elsewhere to this Post. Click to view. #1 (permalink)
Default BIOS Bad Checksum
I Have a Asus Motherboard Model No K8V-MX and suddenly while booting up i got the messege "BAD Checksum" Bios Recovery.... No CDRom found... no floppy.
I have tried resetting the motherboard bios through jumper and battery, but it did not work.
After that i downloaded the latest bios (K8VMX211.zip) from http://support.asus.com/download/dow...Language=en-us
the file is the latest bios for the same model.
How do i upgrade it with CD(no floppy drive in my system). since the system is not booting with windows bootable cd etc.
Note : i dont have the original motherboard CD.
Experience Is not Counted in Years.. But in the Countless Effort
www.kolasib.com www.zoram.org
valtea is offline
Old 22-04-2007, 08:07 PM   #2 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Default Re: BIOS Bad Checksum
Hmm... this is a tough problem. The system is showing no floppy drive as well. Even having a CD ROM is not helping as its not detecting it. If you manage to get a floppy drive, try to flash it again. Else, there is always the repair shop. Why were u flashing the bios?
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 22-04-2007, 08:29 PM   #3 (permalink)
Actually i think the messege is that
The BIOS is trying to repair it self and asking for a recovery floopy/Cd.. that what i think, i may be wrong.
How do i flash it, the file i downloaded has only a BIN file and there is not option of booting even in DOS.
I cant even enter the BIOS Setup... It failed POST
valtea is offline
Old 22-04-2007, 09:00 PM   #4 (permalink)
a_g = JPKN
s18000rpm's Avatar
did you try changing the Battery?
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 22-04-2007, 09:21 PM   #5 (permalink)
shantanu's Avatar
first change the battery and then if possible boot into windows... and download the asus BIOS updater for windows from
http://in.asus.com (in the downloads section) (in utilities)
now intall the software and run it.. select the option of UPDATE from file in the drop down list and browse the file... and then press FLASH.... it will take mere 1 min,, and ask you for a reboot.. i think you will be done...
shantanu is offline
Old 22-04-2007, 09:51 PM   #6 (permalink)
I have changed the battery, not working.
I cant boot into windows (it not passing POST)
Kindly tell me if there is any other solution.
Whil searching for a solution in the net i found that Asus have a Bios Crash Proof which rebuild the bIOS incase of any oproblem with the original CD.
"ASUS CrashFree BIOS 2 - Updates the BIOS using a bootable floppy disk or the mother board support CD."
Since I dont have the original CD, from where can i get (make) the floopy
valtea is offline
Old 22-04-2007, 09:55 PM   #7 (permalink)
phreak0ut's Avatar
Since you have the BIOS, extract it into a floppy(remember, no folders) and boot from it. It should boot atleast from there.........hopefully.
Old 22-04-2007, 10:03 PM   #8 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
^^valtea doesn't have a floppy drive
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 22-04-2007, 10:23 PM   #9 (permalink)
shantanu's Avatar
well now you want atleast a CD-ROM or floppy drive... to get rid of the problem...
shantanu is offline
Old 23-04-2007, 07:19 PM   #10 (permalink)
Thanks everyone for your help. This is what i have done.
Replaced the Battery
Brought a floopy drive and put the latest BIOS Update in it.
Started my PC
"BAd BIOS Checksum"
checking for floopy
Reading K8V-MX.ROM
erasing.....
Programming....
And later i got
Please turn off your computer and turn it on again.
I restarted my PC (From the power plug) but its showing the same thing, i ejected the floopy drive but it shows bad checksum again.
Kindly help
valtea is offline
Old 23-04-2007, 09:35 PM   #11 (permalink)
shantanu's Avatar
you should take your BIOS to the dealer to bought it from.. i think your BIOS battery connector is in trouble.. you have to get it repaired... if its in warranty then it would be very good... otherwise it could be problem...
shantanu is offline
Old 26-04-2007, 02:38 PM   #12 (permalink)
thanks every for your help.
valtea is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/qna-read-only/55824-bios-bad-checksum.html
Bad BIOS checksum error This thread Refback 19-05-2012 04:03 AM
Bad BIOS checksum error - TechEnclave This thread Refback 06-03-2012 04:54 PM
AMD: Bad BIOS Checksum Error This thread Pingback 31-10-2010 03:11 PM
Bad BIOS checksum error This thread Pingback 31-10-2010 02:28 PM
Checksum for Slackware 11.0 aku Open Source 6 19-07-2007 06:16 AM
checksum?????? mak1012 Hardware Q&A 4 09-02-2007 11:51 PM
Bios Checksum Error... deepak_vsoni Hardware Q&A 4 20-11-2005 07:30 PM
BIOS Checksum Error ... jay4u QnA (read only) 6 23-03-2005 07:47 PM
