Old 13-08-2004, 09:13 AM   #1 (permalink)
Default what is this .NET?
Guys anyone with the remotest interest in computers today have heard of something called .NET. But very few know what this actually is. So I would like to place the following questions in front of the forum.
1. What is this .NET? What is it's importance in the software industry?
2. There are so many prefixes to .NET, like VB.NET, Visual c#.NET, ASP.NET. What are the differences between them, if there are any.
3.Supposing i am a prificient c programmer, but know no other language, what is the route i should follow to attain expertise in .NET. And i mean self teaching. No training centres.
technomodel is offline
Old 13-08-2004, 09:16 AM   #2 (permalink)
i forgot to add something. i've heard this .NET is essentially a microsoft thing. does it mean it has no scope in a linux platform? Then what do i need for a similar function.
Old 13-08-2004, 10:39 AM   #3 (permalink)
NikhilVerma's Avatar
even I always wanted to ask this question.
NikhilVerma is offline
Old 13-08-2004, 05:11 PM   #4 (permalink)
aadipa's Avatar
.NET is a framework (system library files) on which applications created with "Visual Studio .NET" will work.
It is microsoft's attept to create something like JRE. In these virtual machines, applications are compiled to some intermediate code instead of pure exe files. So u can work in any of the .NET language at a time to create 1 big project.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 13-08-2004, 08:46 PM   #5 (permalink)
do you mean that it is something like the set of header files(stdio,math,conio etc etc..) which we use to program with c & c++? does it mean i can use any OO lanuage like vb, vc++ or c# to program using the .NET framework? and what are the differences between .Net and JRE ? i mean, if they are similar, why is .NET making such a wave?
Old 13-08-2004, 10:36 PM   #6 (permalink)
Posts: n/a
as aadipa said .net is a platform or u can say framework on which you can easily make projects of enterprise level . . ots a pure oop language .. and as they are vb 6 , vc++6 etc in visual studio similarly vb.net (vb 7 ) vc# .net asp .net are the language included in that package . its fully ms based and its attemp of ms to be in competition with java .. there are many built in object library in that . . and thing u sud learn ..
Old 13-08-2004, 10:49 PM   #7 (permalink)
ok, now supposing i want to master .NET, from where do i start? I may add that i have no experiance oop, though i guess i can say that i am quite comfortable with C (no one can know everything about anything, can he?)
I dont even know the difference between JRE,J2EEand JVM, excepting their full forms
Old 14-08-2004, 12:09 AM   #8 (permalink)
hi,
as discussed .net is a new software development framework developed by microsoft
it has been developed to rival the java runtime environment
however microsoft is more better than JRE in some aspects ( most important u can develop diff program modules in diff languages and still compile them together to make one coplete program)
VC#, Vb.net, Asp.net .. all these are separate software language kits available with the visual Studio.net
howver pls note u can develop any program in any general programming
language ( like c, c++ , basic ,etc ) and linkit to any program module developed in visual studio.net or other language and still it will run
the complete program thats becos vs.net compilers convert all the code to an intermedia language called MSIL ( MS Intermediary Language )
No.. ".NEt " is not like any header file of c,c++
its a complete application development framework
u can download the Framework kit from microsoft website
however with this u hav to use ur text editor for writing progs and make use of ur console (dos prompt) to compile run and execute progs
however if u hav the entire studio.net it has its own "ide" for separate language developemnt kits
vb.net is next form of vb, vc# is a successor of c,c++
asp.net is successor of asp
with any of the .net languages u can develop solutions for the web ( thats the main reason it was designed )
as others said its a complete object oriented language
also
as ur comfortable with c, i would suggest u start with learning C#
u can read tuts from msdn online
or just search google,kazaa,imesh for C# tuts u will find many.. otherwise buy a book called Programming withC# by balaguruswami..its arnd 180 bucks or u can go for C#- the complete ref costing 300 bucks both are good books
to learn C#
for other .nET LANGUAGES U HAV TO READ RESP BOOKS
aLSO NOW DIFF BETWEEN
JRE,J2EE andJVM
JRE - its the environment u require to develop java applets and applications. its just like the ".NET " Framework (which is also an environment)
J2EE
well their are 2 Java development kits available one is the J2SE and the Other is J2EE
J2SE - JAva Standard development Kit (its for general users for general progams and its free abt 30 mb download)
J2EE - Java Enterprise Edition Development Kit ( its for enterprise applications ) it cost money and is more than 100 mb download ( u can hav a trial version for 60 days)
JVM - tats the JAVA Virtual Machine
Java environment has been designed in such a way that every java program u run is isolated from one other
tat is each uns independantly while using its own unique resources( variable, functions, etc)
a virtual machine is nothing but an exact replica of ur system given to eac program . each program runs in a separeate virtual machine ( so if 3 java progs may be running then u hav 3 separate virtual machines providing the environment for executing each program
hope all this helps if more questions pls dont hesitate to post
Attack life, it\'s going to kill you anyway.
walking-techie is offline
Old 14-08-2004, 10:11 AM   #9 (permalink)
wow, thanks walking.that cleared a lot. NOW C#, HERE I COME. I'll keep you posted of my advances and setbacks
Old 15-08-2004, 06:44 PM   #10 (permalink)
aadipa's Avatar
A nice explanation about .NET,
but i would like to comment on ur Java related answer.
JRE is needed to RUN your java applications (JARs) and applets. To develop u need SDK ie software development kit.
There is also a J2ME : Java 2 Micro Edition
It is used mainly in day to day devices like mobile phone, washing machine, and all that is markated as Java enabled
Virtual Machine is not a replica but an entire machine with predefined features with it. It has its own OS and Hardware (Processor) and Processor Instruction Set. So even if any client machine don't support some feature of Java program, JVM (Java Virtual Machine) emulate that and this makes ur Java application platform independent.
aadipa is offline
Old 16-08-2004, 12:31 AM   #11 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
For Dotnet you should visit
www.gotdotnet.com
and
http://msdn.microsoft.com/developercenters/
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 17-08-2004, 08:50 AM   #12 (permalink)
hey guys, i have'nt got the answer to one question. is there any application similar to .NET for the linux platform?
Old 18-08-2004, 02:13 AM   #13 (permalink)
Mono is one ..
http://www.mono-project.com/about/index.html
Its a product of Ximian .. It wasnt that much stable last time I got hold of it ..But it was some 12 mnths back I thnk ...
Old 18-08-2004, 02:16 AM   #14 (permalink)
Hmmm... A google search showed this page ...
http://www.devchannel.org/devtoolsch.../1755236.shtml
I have no experience of DotGNU yet ..
Old 18-08-2004, 03:28 AM   #15 (permalink)
Yup! good discussion ya guys have going on, around here!
prathapml is offline
Old 18-08-2004, 03:37 PM   #16 (permalink)
great discussion!
Keepitup guys !
walking-techie, i wanna know abt XML, is it prerequisite to learn VB.net / ASP.net ?
.........my PC is Phully Computerized !!!!!!!! www.pankajkale.tk
http://www.freewebs.com/pankyprk/colorbarsmallp.jpg
pankyprk is offline
Old 18-08-2004, 05:10 PM   #17 (permalink)
ok guys, i think there are a lot of developers around here, also people doing regular huge projects with OOP. so i put this question, which language do you prefer, j#, c++ or c#. and which environment do u like more, jre or .NET?
i guess i can start a poll too
Old 19-08-2004, 12:42 AM   #18 (permalink)
mono has grown into a more mature release now
Old 04-09-2004, 11:38 PM   #19 (permalink)
jpushkarh's Avatar
Well done
Great Job Guys
Keep it up >>>>
jpushkarh is offline
