sid311 wrote
thanks mamba for replying....... since u r an amd fan let me ask you..... as u said i should go in for amd 3200+ (939) and an asus m/b .... cud u tell how much this combo costs in delhi as the Nehru Place site is not a good indicator for this... also which graphix card which has performance should i use for this system....my budget is 15 k... also i hav heard that with an asus m/b the 6600 gt card the system hangs while playing games...
i hope u guys will be able to help me in amd platform as i am new to this platform.... and my budget for a pc is 60k....... Pls suggest... !!!
Where did you hear that ASUS Mobo hangs system while playing games
Is the Mobo you are refering a ASUS A8N-SLi
Because i havent heard of any such thing, it might have happened
due various reasons the Mobo might not be the only culprit. Do verify your
self before stating any remarks about any product.
Motherboard I will still say go for ASUS A8N-Sli
Also for such a fabulous system i highly recommend you
Kingston HyperX
KHX3200ULK2/1G [1GB 400MHz DDR Non-ECC CL2 ]
400MHz (PC3200) 2-2-2-5-1 (CAS Latency 2)
This is a very fast working DDR400 Ram Module
Please note down the Model No for this Ram based on my experience
I am telling you to go for this ram.
This RAM is especially for Gamers and High End Machines.Its a Dual Channel Kit of 2 x 512MB Ram DDR 400 Ram.
Dont go for Transcend Ram.
Kingston Contacts:- AA Infoway - New Delhi - 26442261/51618351
Graphics Card :- XFX6600GT PCIX16 [2 Modules @ Rs24000]
Pioneer DVR-108 DVD Writer 16X also has Dual Layer support at 4x
Rs 6300 in Nov 2004 might have come down now.
If you are 100% Sure that you are gonna take 2PCIx16 GPU's
get a 500Watts Power Safe Power Gold Plated supply Rs 2000
else a 400Watts Power Safe Supply Gold Plated for Rs 1500
Remember choosing a correct power supply is very important choosing
a higher watt power supply doesnt mean that your system will run better.
Choose a correct power supply.
Well these are my recommendations
