Hey anand,
okie... HijackThis dint solve the problem.. but it did help me remove a lot of other crap.. so thanks anyways..
actually i discovered the solution....
now as i had said ie used to pop up randomly.. it always used to redirect me to
url.cpvfeed.com.. now i dunno hw many know this but this is the problem.
Its malware.. no point scanning ur system with avg / norton / mcafee with latest updates.. does not solve anything.. Ad Aware and Spybot dont solve anything either..
go to
c:\windows\system32\drivers
you will find a file called
core.sys.. the trick is to delete this.. in normal windows mode you cant.. also if you try to upload the same to
www.virustotal.com, it does not work, cuz the malware prevents the upload...
the error msg is "Upload file length is 0 bytes"...
only soln that i found is this..
1) Restart windows in safe mode
2) Delete the
core.sys file.
You might also find a cache file for core.sys. delete this too.
3) Restart the system in normal mode.
4) Voila!! Problem gone.....
Just thought i would post this.. I dunno how many ppl have the same prob n in case they do, they can use this soln..
anand since u r pretty well knwn in these circles i would definitely suggest you start a new thread n propogate this...
ppl are more likely to listen to you than me brother..
and yeah... thanks a lot for your help n suggestions too!!!
Ciao!!!
