Old 20-04-2007, 12:45 PM   #1 (permalink)
ruturaj3's Avatar
Default How to run .bat file in vb
Can any one tell me how to edit & execute .bat files in vb application form.
ruturaj3 is offline
Old 20-04-2007, 11:21 PM   #2 (permalink)
[A]bu's Avatar
Default Re: How to run .bat file in vb
open a file in output mode having extension .bat. Now type codes...
just then use shell cmd in vb and locate the path
Do or Die
http://www.hamrobrt.com/howto-install-flash-player-in-ipad/
[A]bu is offline
Old 22-04-2007, 09:50 AM   #3 (permalink)
Mad and Furious
redhat's Avatar
Do you want to execute a batch file????
Then use this:
Dim RetVal
RetVal = Shell("C:\mybatch.bat", 1)
The general syntax to use this is :
RetVal = Shell([Pathname of EXE],[WindowStyle As vbAppWinStyle = vbMinimisedFocus])
redhat is offline
i have a 2o mb rar file which becomes a 2gb iso file.how do i do it with other stuff? tango_cash Software Q&A 8 27-12-2006 10:47 PM
what is this file???? william QnA (read only) 1 06-05-2006 04:32 PM
Change File size in MB instead of GB in properties of a File rachitar QnA (read only) 4 24-11-2005 09:46 AM
How to convert a VDV (*.vob) file in to VCD (*.dat) file Choto Cheeta QnA (read only) 2 17-09-2004 01:47 AM
