Old 19-04-2007, 03:55 PM   #1 (permalink)
Question Remove the task pane from Desktop
As you can see in the picture somehow the default task pane found in windows explorer has appeared on the desktop.This happened after I changed the resolution of my computer from 1152x864 to 1024x768.The same has not occurred in other users account.I use XP service pack 2
Please tell me how to remove this.
Areeb Khan is offline
Old 19-04-2007, 03:59 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Remove the task pane from Desktop
http://www.dougknox.com/xp/utils/XP_CommonTasks.zip
To use: Download the XP_CommonTasks.zip file and save it to your hard drive Locate and double-click the file you just saved and extract XP_CommonTasks.exe. Double click XP_CommonTasks.exe to run the utility. You will need to log off/log on or reboot for the change to take effect. There is no install/uninstall. Simply delete the EXE file to remove it.
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 20-04-2007, 03:11 PM   #3 (permalink)
Thanks a lot Sukhdeep for helping me!
Remove shortcut arrow from desktop icons Tech Geek Tutorials 9 06-11-2006 09:42 AM
(desperate ungeek) confused about wrong task pane template fix d4l3d Software Q&A 3 16-07-2006 04:51 PM
WANT TO REMOVE THE TEXT FROM YOUR DESKTOP ICONS ? anandk Software Q&A 9 19-05-2005 01:57 PM
how can i remove or desable an user task in Kaspersky?? Choto Cheeta QnA (read only) 3 13-04-2005 11:12 PM
Help needed to remove Desktop Hijacker from my PC.... Yoda QnA (read only) 7 18-01-2005 10:45 AM
