Old 18-04-2007, 04:51 PM   #1 (permalink)
speedyguy's Avatar
Default widescreen issue!!
hello all,
i just wanna know whether i can use full screen in flat display for laptops while viewing a video in win media player or any other player....i have a 12.1 wide screen from hp n video display does not completely pan n scan to widescreen view but there r cut outs from both sides...ie. some gap is left blank on both sides
Enjoy~!
No Pain...No Gain
speedyguy is offline
Old 18-04-2007, 06:54 PM   #2 (permalink)
aryayush's Avatar
Default Re: widescreen issue!!
This depends on the aspect ratio of the video and your screen. If your screen has an aspect ratio of 16:10 and the video is 16:9, there will be gaps on the top and bottom. If the ratio is something like 3:4, there will be gaps on the left and right.
However, you can use VLC media player to do what you want. When the video starts playing, select your aspect ratio from the video menu in the menu bar. Be warned though that if you select a ratio that is drastically different from the video's native ratio, it might become terribly disproportional.
Feel free to shoot any other queries.
aryayush is offline
Old 18-04-2007, 07:11 PM   #3 (permalink)
Super Saiyan
Goten's Avatar
Its really better to choose the aspect ratio same as ur video coz u will get clarity in that.
I use a HP Laptop 15.4" wide n its better if u watch it that way n do not make it full screen.
Peace~~~!
Goten is offline
Old 18-04-2007, 07:48 PM   #4 (permalink)
speedyguy's Avatar
u got 15.4 thats ok buddy...but mine is almost like a pda of 12.1 inch(hp tablet)...from such a small screen further cuttings wont luk nice
ps: checking vlc...any other advice!!! is it safe playing wit the ratio?
Enjoy~!
No Pain...No Gain
Old 18-04-2007, 08:17 PM   #5 (permalink)
aryayush's Avatar
What do you mean by "safe"? I can assure you that you won't be attacked by militants if you change the aspect ratio, for one thing.
aryayush is offline
Old 18-04-2007, 10:33 PM   #6 (permalink)
speedyguy's Avatar
ya thanx aryaayush....act safe i mean for my poor lil lappy nt fr me...hope any sort f militants wont attack it eithr...
Enjoy~!
No Pain...No Gain
Old 18-04-2007, 11:07 PM   #7 (permalink)
aryayush's Avatar
So, did you figure it out? Is it working as expected?
aryayush is offline
Old 29-04-2007, 12:55 PM   #8 (permalink)
speedyguy's Avatar
hi i chekcd out vlc its workin fine but drwbacks....i cant use my remote or multimedia keys to operate d player....isnt thr ne way to make it work in widescreen in win media player 11 wit vista
Enjoy~!
No Pain...No Gain
Old 29-04-2007, 01:23 PM   #9 (permalink)
a_g = JPKN
s18000rpm's Avatar
man !
it took like more than 10 days to try
No offence , jus jokin
ASUS K53SV SX520D + BF3
s18000rpm is online now
NFS:Carbon widescreen tool W i d e S c r e e N Gamerz 8 29-03-2009 01:04 PM
TV tuner 4 widescreen 20inch LCD ranjan2001 Hardware Q&A 9 02-03-2007 11:15 AM
TV Tuner for 19" Widescreen ?? ShekharPalash Hardware Q&A 1 30-12-2006 10:19 AM
19 inch LCD monitors.(Widescreen and Normal) I Do Not Have A Username. Hardware Q&A 22 13-12-2006 12:17 AM
Viewsonic LCD 19" Widescreen pulkit101 Hardware Q&A 6 09-12-2006 10:05 PM
