09-02-2005, 06:14 PM
mekalodu
eclipse
how do i install the eclipse 3.0.1 SDK given in this month's Digit DVD?
it refuses to install in my winXP pro
plz help
09-02-2005, 06:20 PM
why need title?
Re: eclipse
wat does the message it says?? wat u mean by refuse??
10-02-2005, 08:40 AM
Just extract the eclipse zip folder to any place you want.Then make sure you have the Java 2 runtime envoronment.In case you do not have it you can install it from the digit dvd(i don't remember which month may be nov or dec.check it.)Then run the eclipse.exe file.
10-02-2005, 05:59 PM
mekalodu
java runtime is installed but i just get the hourglass symbol in my mouse pointer and it goes off without giving any error
eclipse is not installed!!
mekalodu
10-02-2005, 06:20 PM
JRE might be installed however it might not be in you PATH variable. Do the following :
open up a command prompt.
Goto the directory whe eclipse is installed. I am assuming that you have installed it in C:\ecplise so say cd c:\eclipse
now just type java -version. This will give you the version of JRE you have installed. If this command returns a java is not recognized as an internal or an external command error then your JRE is not in the PATH or your PATH variable has been modified.
case 1 :
java command gives error. Then do the fllowing. Right click on My computer and select properties. Click on the advanced tab and select Environment Varibles button which is to the bottom. Then in the system variables there will be a PATH variable. Double click it and in the value row enter the location of your JRE bin directory for example c:\jre\bin (change this accordingly). Save it and close the properties window. You will need to close the command prompt window and open a new one and perform the above mentioned stepd once again.
Case 2:
The java command works fine yet eclipse fails. Then try this. Type the following command. "Set JAVA_HOME=<location of your JRE or JDK>" and then try running eclipse from inside the command window.
Hope this helps.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
13-02-2005, 03:49 PM
mekalodu
well sorry
eclipse itself is not getting installed ...
java path
j2ee
j2ee_home
java_home
all these paths are set correctly ..
i m learning j2ee .....
just a few days back i tried to install eclipse from Digit DVD and i got and error in a message box as soon as i clicked the eclipse setup file
the error says
ECLIPSE_STARTUP_ERROR_CHECK_LOG
what cud be the reason...
mekalodu
25-02-2005, 10:43 AM
mekalodu
does eclipse given in digit DVD require java
J2SE 5.0 ?? and J2EE 1.4 ??
i have the following installed ...
J2EE 1.4 SDK
J2SE 1.4.2 SDK
mekalodu
25-02-2005, 11:35 AM
Eclipse needs only JDK 1.4 and above. So what you have installed is fine. There is no installer for eclipse. It just needs to be extracted to a dir and run from there and it will work. Been using it for ages.
AMD 64 3500+ Venice
25-02-2005, 12:56 PM
mekalodu
my eclipse is not working ....
when i double click eclipse.exe file i get an error
i had posted the same in my earlier posts ....
well
sud i extract it into any specific folder ...like
program files
or system32?
plz help....
mekalodu
25-02-2005, 05:20 PM
We need to see what exactly the error is. CHeck the log file and post it here. The log file should be in the same directory.
AMD 64 3500+ Venice
25-02-2005, 06:22 PM
mekalodu
well this seems to b the log file .....
!SESSION Feb 25, 2005 16:51:35.586 ---------------------------------------------
eclipse.buildId=M200409161125
java.version=1.4.2_03
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
!ENTRY initial@reference:file:h:/Go!Zilla Downloads/eclipse-SDK-3.0.1-win32/eclipse/plugins/org.eclipse.core.runtime_3.0.1/ 0 0 Feb 25, 2005 16:51:35.606
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: BUNDLE_ACTIVATOR_EXCEPTION
at org.eclipse.osgi.framework.internal.core.BundleCon textImpl.startActivator(BundleContextImpl.java:975 )
at org.eclipse.osgi.framework.internal.core.BundleCon textImpl.start(BundleContextImpl.java:937)
at org.eclipse.osgi.framework.internal.core.BundleHos t.startWorker(BundleHost.java:421)
at org.eclipse.osgi.framework.internal.core.AbstractB undle.resume(AbstractBundle.java:366)
at org.eclipse.osgi.framework.internal.core.Framework .resumeBundle(Framework.java:999)
at org.eclipse.osgi.framework.internal.core.StartLeve lManager.resumeBundles(StartLevelManager.java:577)
at org.eclipse.osgi.framework.internal.core.StartLeve lManager.incFWSL(StartLevelManager.java:488)
at org.eclipse.osgi.framework.internal.core.StartLeve lManager.doSetStartLevel(StartLevelManager.java:27 3)
at org.eclipse.osgi.framework.internal.core.StartLeve lManager.dispatchEvent(StartLevelManager.java:444)
at org.eclipse.osgi.framework.eventmgr.EventManager.d ispatchEvent(EventManager.java:186)
at org.eclipse.osgi.framework.eventmgr.EventThread.ru n(EventThread.java:104)
Caused by: java.lang.NoClassDefFoundError: org.eclipse.osgi.service.environment.EnvironmentIn fo
at org.eclipse.core.internal.runtime.PlatformActivato r.acquireInfoService(PlatformActivator.java:223)
at org.eclipse.core.internal.runtime.PlatformActivato r.start(PlatformActivator.java:59)
at org.eclipse.osgi.framework.internal.core.BundleCon textImpl$1.run(BundleContextImpl.java:958)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.framework.internal.core.BundleCon textImpl.startActivator(BundleContextImpl.java:954 )
... 10 more
Root exception:
!ENTRY initial@reference:file:h:/Go!Zilla Downloads/eclipse-SDK-3.0.1-win32/eclipse/plugins/org.eclipse.update.configurator_3.0.0/ 0 0 Feb 25, 2005 16:51:35.646
!STACK 0
Caused by: java.lang.NoClassDefFoundError: org.eclipse.osgi.framework.log.FrameworkLog
at org.eclipse.update.internal.configurator.Configura tionActivator.acquireFrameworkLogService(Configura tionActivator.java:468)
at org.eclipse.update.internal.configurator.Configura tionActivator.start(ConfigurationActivator.java:70 )
... 10 more
Root exception:
!ENTRY org.eclipse.osgi Feb 25, 2005 16:51:35.656
!MESSAGE ECLIPSE_STARTUP_STARTUP_ERROR
!STACK 1
java.lang.IllegalStateException: ECLIPSE_STARTUP_ERROR_BUNDLE_NOT_ACTIVE
at org.eclipse.core.runtime.adaptor.EclipseStarter.en sureBundlesActive(EclipseStarter.java:303)
at org.eclipse.core.runtime.adaptor.EclipseStarter.st artup(EclipseStarter.java:227)
at org.eclipse.core.runtime.adaptor.EclipseStarter.ru n(EclipseStarter.java:127)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Nativ e Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknow n Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Un known Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.core.launcher.Main.basicRun(Main.java: 185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
mekalodu
25-02-2005, 08:51 PM
ok. There seems to be an error with the release. Could be several reasons. Try the following :
1)Try extracting it to a different location and then run eclipse.
2) uninstall your Java and reinstall it.
3) Try installing JDK5 and then run eclipse and see if it works.
4) Well if all of the above fails download eclipse from the site and test it. I didnt install the IDE at home. Will check it out and let you know.
AMD 64 3500+ Venice
25-02-2005, 10:55 PM
mekalodu
ok thanks i will try ur suggestion...
mekalodu
26-02-2005, 11:46 AM
mekalodu
i extracted eclipse file in c drive n it stated working .....
thanks for ur help
does eclipse have a drag n dorm feature .... for creating buttons and textboxes ...??
mekalodu
Search this Thread |
