Old 18-04-2007, 10:20 AM   #1 (permalink)
Question PLS help me!!!!!!!guys
hi..i hv got a new DVD writer LITE ON LH 20A1P ..i hv installed it in my PC as a master drive and made my existing combo drive as a slave.but the dvd writer is unable to run DVD/CD properly.it can burn CD/dvd well.MY combo drive is perfect.
wen i insert a DVD/cd(in my dvd writer) with autorun and a interface...like DIGIT/skoar DVD i get the following message
http://www.flickr.com/photo_zoom.gne...3649799&size=o
wen i try to accesss any dvd/cd frm MY COMPUTER ,,i get the following message,
http://www.flickr.com/photo_zoom.gne...3649745&size=o
zoom the images if they appear small..
pls help as fast as u can!!!!!!!!!!
themostwantedprince is offline
Old 18-04-2007, 10:21 AM   #2 (permalink)
Exclamation pls help me!!!!!!!!!!
Old 18-04-2007, 01:56 PM   #3 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
Default Re: PLS help me!!!!!!!guys
try updating the firmware of ur dvd drive , also check the master/slave jumper settings , lastly try accesing it through the command prompt
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 18-04-2007, 09:42 PM   #4 (permalink)
wid million core procesor
davinci's Avatar
once i got a similar problem (but it was my cd writer) but it turned out that the cable was loose and after fitting it well the problem was solved. so check for any loose cable.
Intel C2D E4300|4GB DDR2 800 RAM|1.5 TB HDD|Nvidia GeForce 9500GT 512MB DDR3|
davinci is offline
Old 19-04-2007, 05:08 PM   #5 (permalink)
Update your dvd firmware.
abhijangda is offline
help guys....? LEARNER_LEARNER Open Source 4 21-12-2006 01:33 PM
Guys help me buy a new pc.... huzaifa b arab Hardware Q&A 2 12-07-2006 04:11 PM
help me out guys gowtham Hardware Q&A 12 13-06-2006 08:34 PM
Help Me Guys Creative-Eye Software Q&A 1 23-11-2005 06:39 PM
