Old 17-04-2007, 11:49 AM   #1 (permalink)
Question System restore
Is there any tool available which allow you to run system restore in DOS mode when you can't log into windows ?
ThinkFree is offline
Old 17-04-2007, 03:55 PM   #2 (permalink)
piyush gupta's Avatar
Default Re: System restore
Means?
Can u explain a bit more what exactly u wanna to do?
piyush gupta is offline
Old 17-04-2007, 05:11 PM   #3 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
u can try norton ghost though , u can boot from ghost software disk n make n image n restore .
Norton ghost is another software n it will not restore files using windows restore points , it uses it's own format .
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 17-04-2007, 08:02 PM   #4 (permalink)
Buddy i think ghost is used to clone HDD
Old 17-04-2007, 10:27 PM   #5 (permalink)
Fresh Stock Since 2005
No, I dont think there is a tool available to boot in dos mode and use the "Windows System Restore" to restore your system to previous state.. You will need to backup with third party tools and restore... Anyways, why do you want to do it in DOS mode??
http://www.khattam.info
khattam_ is offline
Old 17-04-2007, 10:45 PM   #6 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Smile Re: System restore
Yes, If u r able to start command prompt(safe mode) , type %systemroot%\system32\restore\rstrui.exe
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 18-04-2007, 01:49 PM   #7 (permalink)
C# Be Sharp !
@piyush
i know but i meant that u can use ghost to make backup of your hdd or partition regularly n when u wanna backup just restore from that backup.
Old 19-04-2007, 09:46 AM   #8 (permalink)
^^ I appriciate ur knowledge buddy but read his query
it clearly started that he needs to backup on HDD
how can he arrange another HDD for backup using ghost
System Restore Goes Away.... dinesh_mettur Software Q&A 1 19-11-2006 11:47 AM
System Restore-- Big Help s18000rpm QnA (read only) 8 23-03-2006 04:44 AM
system restore....????? john_the_ultimate QnA (read only) 9 11-08-2005 03:41 PM
