Old 16-04-2007, 06:45 PM   #1 (permalink)
Right man in wrong place!
cyborg47's Avatar
Default Keyloggers?????
hi, i wanna know what are keyloggers??? the only thing i know about it is they record keystrokes. What else it does? does it harm my PC?
Quad Core Q9300, Gigabyte EP45usb3 mobo, Zotac GTX 460 1024MB, 3x2 GB ddr3 memory, cooler master extreme 600W.
...They call me Prophet... - C2:twisted:
cyborg47 is offline
Old 16-04-2007, 06:51 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Keyloggers?????
Hope this helps
http://en.wikipedia.org/wiki/Keystroke_logging
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 16-04-2007, 06:57 PM   #3 (permalink)
cyborg47's Avatar
Does it harm my computer while im using the internet?????? Like a spyware does.
cyborg47 is offline
Old 16-04-2007, 07:01 PM   #4 (permalink)
Host4Cheap.org
Keylogger is meant for logging Victim's activities.
If you installed it yourself and monitoring your own activities, it wont harm but i am not sure why you would like to do this in the first place
Old 16-04-2007, 08:47 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
it dznt harm the copm. it keeps a watch on what the user pinches. y someone keeping a watch on u ? or u wanna keep a watch on someone. there r some good freeware keyloggers avlble on the net. search if u want one
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 16-04-2007, 09:08 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
yes..it won't harm ur system.
ravi_9793 is offline
Old 16-04-2007, 10:09 PM   #7 (permalink)
cyborg47's Avatar
can any one give me the direct download link, thanx.
cyborg47 is offline
Old 16-04-2007, 10:20 PM   #8 (permalink)
wid million core procesor
davinci's Avatar
Thumbs up Re: Keyloggers?????
http://www.refog.com/files/keyspectst.exe
try this.havent tried it myself so not sure how it works.i have one but lost the exe file and couldnt find it on google.
Intel C2D E4300|4GB DDR2 800 RAM|1.5 TB HDD|Nvidia GeForce 9500GT 512MB DDR3|
davinci is offline
Old 16-04-2007, 11:56 PM   #9 (permalink)
:-o
aakash_mishra's Avatar
go here......
you can get many keyloggers here
www.amiable.in
aakash_mishra is offline
Old 17-04-2007, 12:22 AM   #10 (permalink)
coolboy_n's Avatar
Hia,
keyloggers r software progs tht,when installed on a system..save all the keystrokes of tht particular system into log files tht may/may not be encrypted.
A keylogger generally harms u only when smone else has *planted* it on ur system to monitor ur activities( Online as well as Offline )..else the only way it can harm u is by 'taking up ur precious CPU'.
These days..we've Remote Installation keyloggers which can be remotely sent to the victim to be installed onto his/her comp without 'em knowing.
It saves all the keystrokes(including passwords n all ) into a log file and may send these logs to the remote-hacker ..who in turn can get all ur info.
Keyloggers these days hve an option to download some other files directly from the internet ( thru urls generally given by the hacker) and get them executed..which can ..pretty obviously be extremely hostile n dangerous for ur system.
Examples of such keyloggers r perfect keylogger,golden keylogger & Sc keylog.
Use google and find more info ..!!
You make your Living with what you Get,
But you make your Life with what you Give !!
coolboy_n is offline
Old 17-04-2007, 08:57 AM   #11 (permalink)
Host4Cheap.org
I hope i am not breaking the rules, if i am MODS i am sorry and feel free to delete this post.
Best Kerylogger can be downloaded from here
http://www.ardamax.com/
Tool to defeat Keyloggers blackpearl QnA (read only) 16 26-12-2006 09:19 PM
