Step 1 : Go to
www.md5summer.com and download the program md5summer. Install it.
Step 2 : Use the program to generate the md5 checksum of your iso image (The one you downloaded, and then recovered).
Step 3 : Download the checksum from the same site you downloaded the image from (preferably the same mirror).
Step 4 : Compare the two checksums.
If they're the same, you downloaded an uncorrupted file, and the problems probably came while burning or something. If the checksums don't match, then the file was corrupted and you'd be better off redownloading.
