Old 15-04-2007, 04:39 PM   #1 (permalink)
Alive Again...
satyamy's Avatar
Question Localhost........?
I have learnet to make localhost in your own computer sometime before
but now i have forget it
Can someone pls tell me how to create Localhost
i.e.
if i copy some html files like index.html in that root folder & run http://localhost/ than that html file will open directly
I remember a little that it should be made by going to Administrative Tools in Windows XP
Pls help............
satyamy is offline
Old 15-04-2007, 05:27 PM   #2 (permalink)
eWebGuru
ahref's Avatar
Default Re: Localhost........?
You need to have a web server (IIS or Apache) running on your PC for it.
Windows and linux hosting at http://www.ewebguru.com
Get $50 per blog post PM me for details.
ahref is offline
Old 15-04-2007, 05:29 PM   #3 (permalink)
Alive Again...
satyamy's Avatar
ohh yes
i have IIS on my PC
can u tell me how to make localhost from this
satyamy is offline
Old 15-04-2007, 05:37 PM   #4 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Best way would be to install EasyPHP on your PC
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 15-04-2007, 05:40 PM   #5 (permalink)
The Unknown's Avatar
If you use Opera, input http://localhost/(Drive Letter)/file.html
Ex. http://localhost/C:/index.html
It works. Dont ask me anything more coz i am a linux user.
KDE on ArchLinux
The Unknown is offline
Old 15-04-2007, 06:10 PM   #6 (permalink)
Rebooting
Choto Cheeta's Avatar
u may install EasyPHP it would inlude Apache !!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 15-04-2007, 06:39 PM   #7 (permalink)
Alive Again...
satyamy's Avatar
ok i will install it
but can someone tell me the procedure
satyamy is offline
Old 15-04-2007, 07:05 PM   #8 (permalink)
Host4Cheap.org
Download EasyPHP from Easyphp.org. You will see download dialog...ssave to Desktop. Double click the file you downloaded...click NEXT NEXT Finish.
Thats the procedure
Run EasyPHP and right click on EasyPHP tray icon. Select Localhost
Fedora Core 6:Localhost login? Cool G5 Open Source 45 28-05-2007 05:31 PM
"http://localhost:9100/proxy.pac" problem in IE6 taken Software Q&A 5 04-03-2006 01:44 PM
403 for Joomla,xoops on Apache localhost desertwind Open Source 11 12-02-2006 02:08 PM
problem accessing localhost niranjan_mcarenyold QnA (read only) 2 30-07-2005 03:09 PM
