Old 15-04-2007, 02:05 AM   #1 (permalink)
Phenom II X4 920 Owner
prateek_san's Avatar
Default How to extract the .SFV file====HELP!!!
guys please help i have downloaded a few files naming e.g."xxx.avi.001","xxx.avi.002"....and on ...... i have also downloaded the .SFV file which was also required.... now how can i see the video as a single file......
please help guys...
thanks...
"A strong positive mental attitude will create more miracles than any wonder drug." - Patricia Neal
prateek_san is offline
Old 15-04-2007, 03:02 AM   #2 (permalink)
El mooooo
eddie's Avatar
Default Re: How to extract the .SFV file====HELP!!!
SFV file is nothing but a checksum file...something like MD5SUM. It can be used to ensure that the files you downloaded are not corrupt but not for extraction purposes. There must be some other file in the tree that needs to be extracted. Why don't you list the contents of your downloaded folder here and then may be we can help?
eddie is offline
Old 15-04-2007, 03:24 AM   #3 (permalink)
thanks buddy...but their is no info on the page from where i downlded it........
Old 15-04-2007, 11:50 AM   #4 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
READ MORE ON SFV HERE
rakeshishere is offline
Old 15-04-2007, 01:50 PM   #5 (permalink)
thanks for the help guys...but winrar is not taking "xxx.avi.001" as a extraxtion file.......thats the problem....
Old 15-04-2007, 04:31 PM   #6 (permalink)
pra_2006's Avatar
u need HJ Split search it on google u will get it size is about 600KB
pra_2006 is offline
Old 15-04-2007, 04:45 PM   #7 (permalink)
Thumbs up Re: How to extract the .SFV file====HELP!!!
Originally Posted by Indyan
So that means it wasnt split with Winrar. May be try HJSplit.
See
http://www.binaries4all.com/001/
its a big help........ really thanks.....
how to extract a partially downloaded .rar file shashank_digitreader Software Q&A 6 04-11-2006 08:24 PM
how to extract and merge audio into an AVI file nd4spd Software Q&A 7 18-08-2006 12:57 PM
How to extract ??? rakesh-the gilli Software Q&A 8 03-08-2006 10:58 AM
How do i extract these ?? mohit Software Q&A 11 18-02-2006 06:43 PM
extract a part of a vob file cybermanas QnA (read only) 1 05-10-2005 09:02 PM
