Old 14-04-2007, 01:13 PM   #1 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default .VOB cutter
IS there any s/w (free) which will hell me cut a .vob file smothing like VCD cutter???
wizrulz is offline
Old 14-04-2007, 02:11 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: .VOB cutter
Don't know about Free version
But you can use Ultra Video Splitter(Trial Version)
Third Eye is online now
Old 14-04-2007, 02:23 PM   #3 (permalink)
use dvd decrypter
Jitin was Here.
Jitin is offline
Old 14-04-2007, 03:11 PM   #4 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Originally Posted by Jitin
use dvd decrypter
u sure it will help will give it a try and will let u know
wizrulz is offline
Old 14-04-2007, 03:11 PM   #5 (permalink)
Still Shining!
Lucky_star's Avatar
Try Chopper XP. Its a freeware and works very fast..
Nokia N86 8MP
Lucky_star is offline
Old 14-04-2007, 04:06 PM   #6 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
PROBLEM SOLVED
SOLUTION:
CHOPPER XP
THANKS TO: LUCKY STAR
and also to others who took time to oslve my problem
wizrulz is offline
Old 14-04-2007, 04:23 PM   #7 (permalink)
Tech Geek's Avatar
Vob splitter
http://www.digital-digest.com/dvd/do...itter_386.html
Hmm i am late
Tech Geek is offline
Old 14-04-2007, 04:35 PM   #8 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Originally Posted by Tech Geek
its not that ur late...its that i got to solution be4 u could u guide me...
anyways to all who will be vewing this thread...really use CHOPPER XP...FAST, gives freedon to view the movie while i am cutting ..so i know how much to cut and add......tech geek give it a try
wizrulz is offline
Old 14-04-2007, 04:37 PM   #9 (permalink)
Tech Geek's Avatar
Ok
i'll try it when i get some empty space in my disk..
Old 14-07-2007, 06:05 PM   #10 (permalink)
Chopper XP isn't working fine for me. The vob file is cutted after abt 30-35 sec or my 'MARK IN' selection...plz suggest any gud alternative
Thanks
prabhatmohit is offline
Old 28-07-2007, 12:22 PM   #11 (permalink)
U can use hero player
ajay1287 is offline
Old 29-07-2007, 12:45 PM   #12 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
@Lucky_star ........ thanx 4 wonderful software ..ll.............
... W H O T ...
ax3 is offline
Old 29-07-2007, 01:00 PM   #13 (permalink)
slugger's Avatar
i d posted a soln here
[my 2nd post der]
also a FREEWARE also duz d reverse process also check out its size
slugger is offline
Dvd Cutter Anurag A Software Q&A 4 15-12-2006 07:23 PM
DVD cutter???? photon Software Q&A 2 09-05-2006 10:09 PM
Except VCD Cutter!!!!!!!!! SHell QnA (read only) 4 04-08-2005 05:49 PM
VOB CUTTER OR DVD CUTTER vijaythefool QnA (read only) 6 14-05-2005 07:17 PM
dvd cutter tweety_bird_bunny QnA (read only) 3 26-10-2004 06:23 PM
