Changes from 1.70 -> 1.71 | (2007-04-13):
- Updated ffdshow to revison 1097
- Updated x264 VFW to revision 621
- Removed DirectVobSub 2.33. It is available as a separate installer.
- Removed Morgan Multimedia Stream Switcher. It is available as a separate installer. Most modern players and also Haali Media Splitter already have a build in stream switcher.
- Removed Voxware MetaSound decoder. It is available as a separate installer.
- Improved Codec Tweak Tool
- Improved .mov downloader
- This version of the codec pack does not support Windows 98/ME/NT4. Users of these old Operating Systems don't need to worry. There will be future versions of this codec pack that will work on these old versions of Windows. A pack that runs on all versions of Windows will be released every few months or when there are important changes/updates. The previous version of this pack runs perfectly fine on Windows 98/ME/NT4.
Quicktime alternative is warex or cracked whatever you wanna call it.
If you open the control panel applet for quicktime, you will see that quicktime alternative installs Quicktime Pro, using a common key for all the installation. I dont think this is legal.
