Old 13-04-2007, 01:43 AM   #1 (permalink)
In search of light...
abhi.eternal's Avatar
Default How do i test PHP files?
I have got many PHP files on my machines. But when I try to open them with FF 2, IE 7 or Opera 9, I am getting a message to save the file. I tried to open it with Dreamweaver, but there I get a message to specify a testing server. Even after specifying one, no results. Can I preview those PHP files on my machine in any way?
http://abhijeetdeb.com
abhi.eternal is offline
Old 13-04-2007, 02:44 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: How do i test PHP files?
Windows By default doesnt come with a Server apllication of php, therefore u need a server application like Apache, and php installed...
Get Easyphp, it will do all those job !!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 13-04-2007, 02:53 AM   #3 (permalink)
The dnld size is too much for my dial-up. Is there some lite alternative?
How can I be also a MS MVP?
Old 13-04-2007, 03:00 AM   #4 (permalink)
18 Till I Die............
Maybe then you can install IIS server from windows CD and then download and install PHP.
It's about 9MB http://in.php.net/downloads.php#v5
http://www.bash.org/?258908
mehulved is offline
Old 13-04-2007, 08:46 AM   #5 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
One more Vote for EasyPHP. For viewing a PHP file on your computer, you need them to parse through PHP and MySQL Server. You also need Apache or someother Web Server.
Simple Way, would be...to just install EasyPHP and then you paste you php files in C:\Program Files\Easy PHP\www.
Then run Easy PHP and point to browser to http://127.0.0.1 and you can run your PHP files from there
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 14-04-2007, 01:56 AM   #6 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
BTW I recommend Xampp. its much better than EasyPHP. Get it from apachefriends.org But yeah its download size is much larger than EasyPHP.
@tech_your_future
BTW in windows cd where is IIS? I never found it on my windows xp cd?
navjotjsingh is offline
Old 14-04-2007, 02:25 AM   #7 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
@tech_your_future
Go to CONTROL PANEL-->Add/Remove Programs-->Click Add/remove windows components where u will find IIS.Check the selection and insert the windows cd to install from it
Last edited by rakeshishere; 14-04-2007 at 02:25 AM. Reason: Automerged Doublepost
rakeshishere is offline
Old 14-04-2007, 02:27 AM   #8 (permalink)
I am Optimus Prime
Thanks for telling. I never knew that it was there. failed to notice!!
Old 14-04-2007, 02:32 AM   #9 (permalink)
Even I didn't know until I was told about this at Aptech. I didn't know of apache then, otherwise would never have installed IIS. I use apache on my home PC, and find it really nice.
mehulved is offline
Old 14-04-2007, 03:07 AM   #10 (permalink)
String Phreak
mediator's Avatar
I recommend L.A.M.P. On many distros u have it enabled by default!
About IIS, AFAIR its provided only with XP PRO and the version is 5.1.
mediator is offline
Test Before you Buy techtronic Gamerz 4 01-12-2006 11:09 PM
Speed Test amit2005 QnA (read only) 5 05-11-2006 12:51 PM
Minix! I want to test it. naveenchandran Open Source 4 11-08-2005 07:19 PM
