Old 11-04-2007, 11:06 PM   #1 (permalink)
bukaida's Avatar
Default A PHP script to downsample the image resolution
Can anybody provide any php script which can print the resolution of the selected image(Tiff, jpeg i.e. mainly scanned image) and can be used to downsample the resolution according to user's choice?
Desktop: P-IV 2.4GHz, 512MB DDR, 865GBF Mother Board,
G-Force 5200FX, 17" Samsung flat, WinXp with SP2,
Kaspersky Internet Security 2009.
Laptop:LENOVO 3000 C100 D7 lappy with 2GB DDR2.
bukaida is offline
Old 12-04-2007, 12:31 AM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: A PHP script to downsample the image resolution
Have a look at http://www.phpit.net/article/image-m...-php-gd-part2/
kalpik is offline
Old 12-04-2007, 08:57 AM   #3 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Check this out, it will surely help you
http://vikjavev.no/highslide/#examples
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 12-04-2007, 12:15 PM   #4 (permalink)
tuxfan's Avatar
Have a look at http://in2.php.net/gd
tuxfan is offline
Old 13-04-2007, 02:20 PM   #5 (permalink)
bukaida's Avatar
Does the GD library supports Tiff format? No where it is mentioned clearly.Also in my gd info is----
GD Version: bundled (2.0.28 compatible)
FreeType Support: Enabled
FreeType Linkage: Enabled
T1Lib Support: Disabled
GIF Read Support: Enabled
GIF Create Support: Enabled
JPG Support: Enabled
PNG Support: Enabled
WBMP Support: Enabled
XBM Support: Enabled
JIS-mapped Japanese Font Support: Disabled
Will it do or I have to change something?Tiff support is mainly required.
Also downsampling here mentioned are all about reducing the size, but I want to reduce the resolution(i.e from 600 DPI to 300 DPI or something like that).Please help.
bukaida is offline
Google Image Labeler (New Feature of Image Search) GeeNeeYes Technology News 6 07-04-2007 02:36 PM
Writing image file generated by Image Mixer VCD2 software JBP Software Q&A 3 12-03-2007 05:11 PM
Convert any image to a text image of ASCII characters amitava82 Random News 5 11-02-2007 12:46 PM
Cell Processor VERY high resolution image naveen_reloaded Technology News 6 17-11-2006 11:46 PM
