Old 11-04-2007, 06:44 AM   #1 (permalink)
rajat22's Avatar
Talking Opera 9.20 Build 8771 - Final
Opera is known as the fastest and smallest full-featured browser, a first choice for people using older PCs and Windows 95 and a brilliant alternative to the default IE from Microsoft. Opera, first of all, is client World Wide Web, that is the program for extraction of the information from WWW as the documents created with help HyperText Markup Language (language of a marking of hypertext HTML).
Low requirements to resources of system. Opera will work even on 386 computer about 6 MB of operative memory. MDI the interface. You can open without special expenses of memory any quantity of windows inside one working window, having chosen thus a tabulared or cascade mode.
Features of "Opera for Windows without Java":
*** Efficient surfing:
- Transfer manager. View download progress and access all your downloads from one simple transfer manager window.
- Password manager. The password manager remembers your usernames and passwords so you will not have to.
- Pop-up blocking. Opera lets you control whether to block all pop-ups, or open only the ones that you have requested.
- Fast Forward. Fast Forward will detect the most likely "next page" link and greatly simplify navigation in multi-page documents such as search results and image galleries.
- Quick preferences. Pressing F12 displays the 'Quick preferences' menu to easily switch settings such as pop-up and cookie preferences and more.
- Voice. The voice feature allows you to control Opera's interface by talking and to have documents read aloud. Voice is currently offered in English and runs on Windows 2000 and XP.
- Trash can. If you accidentally close a tab, you can retrieve it from the trash can. This also works for blocked pop-ups that you may want.
- Tabbed browsing. Surf the Web easier and faster by opening multiple Web pages within the same application window.
- Integrated search. Search Google, eBay, Amazon and more with Opera's integrated search. You can also search directly in the address field using shortcuts (e.g. "g" for Google).
- Mouse gestures. Opera supports mouse gestures, allowing you to perform certain movements with the mouse in order to access commonly used features.
- Sessions. Save a collection of open pages as a session, for later retrieval, or start with the pages you had open when Opera was last closed.
- Notes. Notes can be kept in conjunction with a Web site you want to refer to later, to remind you of any particular information you may like to review again.
- Keyboard Shortcuts. Keyboard shortcuts - like mouse gestures - make your browsing faster and more efficient. Read more about all the keyboard shortcuts in Opera.
*** Security and privacy:
- Security bar. Opera displays security information inside the address bar, located next to the padlock icon that indicates the level of security present on a site.
- Encryption. Opera supports Secure Socket Layer (SSL) versions 2 and 3, and TLS. Opera offers automatic 128-bit encryption, the highest available security of any Web browser.
- Delete private data. Opera can be configured to clear the history and cache when exiting, to protect your privacy. Any kind of private data can easily be erased at any time.
- Cookie control. Opera gives you detailed control of what cookies to accept and reject, such as allowing for different set-ups for different servers.
*** Mail and Chat:
- Opera mail. Opera's built-in POP/IMAP E-mail client is a combined e-mail program, news reader, mailing list organizer and RSS/Atom newsfeed reader.
- IRC chat. Communicate with people all over the world using Opera's IRC chat client. Chat privately or in rooms, or share files with your friends and family.
*** Customization:
- Drag and drop. Using the 'appearance' dialog you can make Opera look almost any way you want. Move buttons and search fields, add and remove toolbars, and so forth.
- Skins. Opera skins can give your browser the look you want. Make the browser your own by giving it the icons and buttons of your choice.
- Language. Opera's user interface is translated into a multitude of languages, and the language can be changed on the fly.
*** Accessibility:
- Zoom. With Opera you can zoom the contents of any Web page from 20%-1000% using the zoom dropdown or the + and - keys.
- Text size and colors. Text size and link styling can be changed using Opera. Text color and background color can also be customized.
- User style sheets. Opera comes with a set of ready-made style sheets, including accessibility style, that can be used to override a Web site's style set completely.
*** Web development:
- Standards support. Opera prides itself in supporting all major Web standards currently in use, including CSS 2.1, XHTML 1.1, HTML 4.01, WML 2.0, ECMAScript, DOM 2 and SVG 1.1 tiny.
- Small-screen mode. When displaying a page in small-screen mode (Shift+F11) you can see how it will look on a mobile phone or other small-screen device running Opera.
- Validate code. You can validate the HTML code of any Web page by pressing Ctrl+Alt+v.
- Toggle graphics and style sheets. Graphics and style sheets can be toggled on/off via Opera's menus and shortcuts.
- Info panel. The Info panel shows details about the currently open page such as MIME type, page size, character encoding and more.
- Reload from cache. Edit the source of any open Web page and view the result instantly by using 'Reload from cache' (Tools/Advanced).
*** Special features:
- Full-screen mode. The F11 key toggles Opera's projection mode, using the whole screen for browsing and, if a projection style sheet is present, displays 'slides' suitable for presentation.
- Kiosk mode. Registered versions of Opera supports kiosk mode - a lock-down mode in which the browser can be used for unattended information stands in public environments.
* Fraud protection. Opera's advanced fraud protection protects you against web sites that try to steal your personal information. Watch the demo to learn how to enable this feature.
* Add your favorite search engines. Right-click on the site's search field and select "Create search" from the menu.
* Site preferences. Want to view a site in a different way or deny certain cookies? Want to block pop-ups on certain sites only? Right click and select "Edit site preferences".
* Improved rich text editing. Use advanced text editing features for today's most popular Web applications.
* BitTorrent. You don't need a separate BitTorrent application to download large files. Simply click a torrent link and start the download.
* Content blocker. Remove ads or images - it's up to you. Right-click (CTRL-click on the Mac) on the Web page and choose "Block content".
* Widgets. Small Web applications (multimedia, newsfeeds, games and more) that make your desktop experience more fun. Use the Widgets menu to discover new widgets and access your favorites. Visit widgets.opera.com to learn more.
* Thumbnail preview. It is easy to have many tabs open at once in Opera. But exactly which tab had that video you wanted? Hover your mouse on any tab to see a thumbnail preview.
Changes in Opera 9.20 Build 8771:
Homepage - http://www.opera.com
Download English (US) - 4.67 MB
http://mirror.switch.ch/ftp/mirror/o..._Eng_Setup.exe
Download International - 6.14 MB
http://mirror.switch.ch/ftp/mirror/o...onal_Setup.exe
Downloads for All Platforms
http://www.opera.com/download/index.dml
____________________________________________
A person who never made a mistake never tried anything new.
rajat22 is offline
Old 11-04-2007, 07:36 AM   #2 (permalink)
Default Re: Opera 9.20 Build 8771 - Final
The Opera homepage still has 9.1 version as latest... The direct download links given seem to go to 9.2 version file but the "download for all platforms" brings to 9.1 version file...
Arun
sakumar79 is offline
Old 11-04-2007, 08:42 AM   #3 (permalink)
gooby pls
Third Eye's Avatar
Thanks for the update
Third Eye is online now
Old 11-04-2007, 09:36 PM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
wonder why but the update still says that i'm runnin the latest version (9.1)
infra_red_dude is offline
Old 11-04-2007, 10:49 PM   #5 (permalink)
powerd ↻ pramod
GeeNeeYes's Avatar
maybe you are running beta version (9.2 or 9.1)
check opera:about for detailed info (version, build)
digit member #17000
GeeNeeYes is offline
Old 11-04-2007, 10:57 PM   #6 (permalink)
a_g = JPKN
s18000rpm's Avatar
for me too, but when the latest version is available on Opera website why worry, just download it manually.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 11-04-2007, 11:45 PM   #7 (permalink)
Wire muncher!
hmm.. the speed dial feature's gud!
Old 12-04-2007, 06:20 AM   #8 (permalink)
Right man in wrong place!
cyborg47's Avatar
I like opera, nevermind the updates, its always a good browser.
Quad Core Q9300, Gigabyte EP45usb3 mobo, Zotac GTX 460 1024MB, 3x2 GB ddr3 memory, cooler master extreme 600W.
...They call me Prophet... - C2:twisted:
cyborg47 is offline
Old 12-04-2007, 10:37 PM   #9 (permalink)
The Frozen Nova
casanova's Avatar
And the final 9.20 is out. I downloaded it today
www.nerdweed.blogspot.com
casanova is offline
Old 12-04-2007, 10:38 PM   #10 (permalink)
Just another linux lover.
subratabera's Avatar
When you click in the address box of opera 9.10 it drops down to select favourite links and various links (where you can drag and drop addresses to make a custom shortcut toolbar). Which provides a very convenient interface. This is a very important feature and gives you one click access of various sites, which is missing in Opera 9.20. VERY SAD...
Today is a most unusual day, because we have never lived it before; we will never live it again; it is the only day we have.
(Registered Linux User #432737 - subratabera.blogspot.com)
subratabera is offline
Old 12-04-2007, 11:16 PM   #11 (permalink)
Pharmaguru
kjuvale's Avatar
Hi,
Yu can get that bar back and its present in 9.2 also.
to get it back
goto tools> click appearance
here goto toolbars and select startbar ...click ok
you dropdown bar is back.
My Photography gadgets :
Nikon D5100 with 18-55mm VR Lens, Nikkor AF-S 50mm 1.8g, Tamron VS 70-300 VC Di
Cullmann NANOMAX 220 Tripod. | Crumpler messenger boy stripes 4000 camera bag :grin:
kjuvale is offline
Old 13-04-2007, 12:42 AM   #12 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
^^ Thanx for the info. Had started to miss that toolbar.
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 13-04-2007, 07:50 AM   #13 (permalink)
a_g = JPKN
s18000rpm's Avatar
a day ago me too, but then after some exploring i got it back (jus like frm kj's method).
i thought it was only on my installation
Old 13-04-2007, 08:43 AM   #14 (permalink)
a_g = JPKN
s18000rpm's Avatar
its easier to bookmark certain web page this way (on start bar).
Old 13-04-2007, 09:13 AM   #15 (permalink)
Beneath The Eyelids
The Outsider's Avatar
don't like the start bar myself, turned it off the very day i saw it first time, maybe it was v8.51, don't remember exactly
The Outsider is offline
Old 13-04-2007, 04:26 PM   #16 (permalink)
Originally Posted by kjuvale
Hi,
to get it back
Thankyou, thankyou, thankyou very very much...My start bar is full of website links and its very difficult for me to live without it. I was too dissapoited when I noticed my most used feature is missing...But now I am happy once again .
Thankyou once again...
Subrata Bera.
Old 17-04-2007, 12:44 AM   #17 (permalink)
Knowledge Nomad
appu's Avatar
Superb wil download it now
appu is offline
Old 18-04-2007, 12:40 PM   #18 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
thanx & downloading NOW ..........
ax3 is offline
Old 18-04-2007, 01:03 PM   #19 (permalink)
I downloaded few days ago, really a nice browser. I love the cool interface.
jack// ani is offline
Winamp 5.33 Build 1100 - Final rajat22 Software Q&A 2 14-02-2007 03:14 PM
WinZip 11.0 Build 7313 Final available !! ms123 Technology News 2 16-11-2006 02:49 PM
Opera 9.02 Build 8585 for Windows - Final rajat22 Software Q&A 1 21-09-2006 11:26 PM
Opera 8.50 Build 7700 for Windows without Java - Final rajat22 Software Q&A 1 21-09-2005 02:20 PM
MSN Messenger 7.5 Final - Build 0299 rajas QnA (read only) 2 24-08-2005 03:18 PM
