Originally Posted by arcticflare
i recently downloaded keylogger. it says it can be used to track the activities of any person we want on the net. is it true?if it is then how is it done?
With a keylogger you can easily track the activities of your prey.
I am using
Invisible Keylogger to accomplish this.Pretty easy to use.In normal circumstances one would never suspect of such a program running in the background.
Select the location of the programs you want to track(i.e. your browsers,IE,Opera etc).Otherwise it will log the entire keystrokes!
It will even mail you the log file!
