Old 10-04-2007, 09:44 AM   #1 (permalink)
JBP
JBP's Avatar
Question How to lock desktop?
How to lock the entities of the desktop, such that it should not allow to create any new shortcuts/files and should not allow the existing file positions on desktop? Can anyone help in this regard....
JBP is offline
Old 10-04-2007, 10:02 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: How to lock desktop?
Locking desktop means, this action, "Windows Key + L"
but what you want it some thing else... !!
Take a look at here Registry tweaks to implement some restriction what you want...
http://www.kellys-korner-xp.com/xp_tweaks.htm
and you may try this too, to make sure that all changes made on the Desktop would not save in next restart !!
Run the command Regedit
Find or Navigate to the Registry Key:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer
Modify/Create the Value Data Types and Value Names as detailed below.
Data Type: REG_DWORD (Dword Value) // Value Name: NoSaveSettings
Setting for Value Data: [0 = Disabled / 1 = Enabled]
Exit Registry and Reboot
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 11-04-2007, 11:51 AM   #3 (permalink)
You can do it using Group Policy as well. Type gpedit.msc in run dialog box and you will find one such option there which allows you to lock desktop settings. Not having ample time just now to tell the exact location of that option.
ThinkFree is offline
Old 11-04-2007, 05:30 PM   #4 (permalink)
I couldnot understand what u exactly want.
if u wantt to lock any software or any file that can be done through on going regedit.exe.
other wise saurav given a good tutorial for it and fallow it
suraj is offline
Old 12-04-2007, 01:09 PM   #5 (permalink)
u can do it using a pendrive too....
reddragon is offline
[Desktop Screenshots] The Official April 2006 Desktop Thread Nemesis Chit-Chat 53 11-08-2007 12:29 AM
Customize Desktop missing from right click on desktop krazydude QnA (read only) 4 24-07-2005 12:47 PM
