Old 09-04-2007, 07:51 PM   #1 (permalink)
Default what do 3 commands do ?
ipconfig /all
ipconfig /release
ipconfig /renew
what each command do ?
what happens after i write all ?
assddd is offline
Old 09-04-2007, 08:04 PM   #2 (permalink)
desertwind's Avatar
Default Re: what do 3 commands do ?
/all - Display full configuration information.
/release - Release the IP address for the specified adapter.
/renew - Renew the IP address for the specified adapter.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 09-04-2007, 08:10 PM   #3 (permalink)
what do you mean by release ip and renew ip ?
after i write all three commands in the same order i wrote them, what happens?
assddd is offline
Old 09-04-2007, 08:17 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
^ http://www.microsoft.com/resources/d....mspx?mfr=true
complete list here http://www.microsoft.com/resources/d....mspx?mfr=true
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 09-04-2007, 08:45 PM   #5 (permalink)
all i want to know is about those 3 commands. please help.
assddd is offline
Old 09-04-2007, 09:11 PM   #6 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
The functions of those commands, desertwind has already told. I think you are confused about what is a IP address. This might help
http://en.wikipedia.org/wiki/IP_address
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 09-04-2007, 09:17 PM   #7 (permalink)
if you know please just tell me what exactly each command do ?
i dont understand anything if you tell me it releases ip address from adapter (i dont even know what adapter is).
assddd is offline
Old 10-04-2007, 12:52 AM   #8 (permalink)
desertwind's Avatar
adapter here means your network card.
release will release the current ip address that is assigned to your card by dhcp.
renew will get you a new ip address from dhcp.
Old 10-04-2007, 09:23 AM   #9 (permalink)
piyush gupta's Avatar
Bole to
If u r ISP has provided u dynamic IP address and u want to download from sites like rapidshare then after each download u can use these commands to generate a new ip for ur system
So no more waiting time
piyush gupta is offline
Old 10-04-2007, 05:18 PM   #10 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
shortcut : it JUST renews ur IP address ..........
now dont keep on asking "whots IP address ?"
ax3 is offline
Old 10-04-2007, 05:31 PM   #11 (permalink)
sivarap's Avatar
hey don't be mean to the kid
Listen up kid......
Your Ethernet card has a MACaddress and a IP address...You can do nothing to the MAC address it is fixed....so forget mac address.....
To communicate to another machine on the network connected via the Ethernet card You need an IP address...
Now...the IP address can be dynamic(ie can be given by your server or router) or it can be static(You mention it as xxx.xxx.xxx.xxx).
When you say it should be dynamic, You can use the commands listed by the great you.
when you give the release command, you(computer/ethernet card) tell the router/server "I don't require the IP given by you anymore, you can give it to someone else"
When you give the renew command, you tell the router/server "I want to keep the address for some more time"(since it might expire after sometime) or "Give me another IP address since mine is gonna expire".........
Got it?
sivarap is offline
Old 11-04-2007, 11:00 AM   #12 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Very well explained Sivarap.
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Pls Help Me Out.. AT Commands/VB.net the.kaushik QnA (read only) 1 07-02-2007 08:11 PM
How to get all Dos Commands sainit QnA (read only) 5 15-12-2006 04:40 PM
~*~ 99 useful run commands ~*~ jrkraj Software Q&A 4 14-09-2006 10:08 PM
RUN commands Raaza QnA (read only) 10 16-08-2006 10:01 PM
say ur commands rajas700 Open Source 8 07-09-2005 06:39 PM
