dude, ur avatar is 33.8KB....get rid of the animation....use a single image and it will b a small file...plus, it is oversized...reduce the size 2 80x80...use irfanview....
you can do that in image ready.
reduce the image size to 80x80 pix.
To reduce the file size u need to delete the frames in between.
But making this image that is 33.79 KB (34605 bytes) to 10 kb will make it look very fast and it won't look cool anymore.
