Old 09-04-2007, 01:18 AM   #1 (permalink)
K750
Posts: n/a
Default converting to AAC .
i want to convert my mp3's to AAC for w800 , how can i do this?
i want Size less and audio average i prefer size over quality .
Old 09-04-2007, 11:54 AM   #2 (permalink)
whoopy_whale's Avatar
Default Re: converting to AAC .
Go to http://media-convert.com/
You can convert your MP3 files to AAC for free using this online converter...
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
Old 09-04-2007, 02:55 PM   #3 (permalink)
Proud Mac Pro Owner
nepcker's Avatar
Use iTunes. It's the best. Get it from www.apple.com/itunes
Microsoft Certified Professional Mac Addict
nepcker is offline
Old 09-04-2007, 03:03 PM   #4 (permalink)
Sup' dude, Sup'
1) dbPowerAmp music converter
2) itunes
Among these two, dbpoweramp is super-light on resources.
ambandla is offline
Old 09-04-2007, 03:10 PM   #5 (permalink)
Proud Mac Pro Owner
nepcker's Avatar
Yeah, iTunes takes a little more resources (especially on Windows), but you get better performance.
nepcker is offline
Old 09-04-2007, 03:49 PM   #6 (permalink)
K750
Posts: n/a
i have itunes , but it directly says Convert it to AAC , i want to lower the bitrate
Old 09-04-2007, 03:55 PM   #7 (permalink)
Sup' dude, Sup'
1) go to Edit menu -> Preferences.
2) Click on Advanced tab
3) click on Importing tab
4) under "setting" select "custom..." and select the bitrate to which you want to rip the songs .
ambandla is offline
converting mkv to dvd divyeshashiya Software Q&A 3 10-12-2006 06:53 PM
Converting from USB 1.1 to 2.0 gauravakaasid Peripherals 15 21-06-2006 08:29 PM
converting dat to mp4... help pls legolas QnA (read only) 3 01-10-2005 09:24 PM
converting CD to DVD rakhunathan QnA (read only) 6 03-09-2005 07:36 PM
converting dvd into cds willrock QnA (read only) 2 09-07-2005 04:20 PM
