Old 08-04-2007, 10:54 AM   #1 (permalink)
Default Hard disk fail's to load OS
Hard disk of segate 80 gb refuses to load windows 98 or XP After completed installing process successfully; First 3 to 5 times boots and work normally but suddenly fails to boot saying irror of hard disk.When I Checked partition table using FDISK it shows 68GB only.
Seeing such problem I performed Low level disk format using segate's DM.
Finally shows 80 GB.
After that I have partitioned the disk C: as primary and D:,E as extended logical partition. Then I installed winxp pro sp2.After normaly booting 5 times suddenly refuses and start frequently boot upto bootscreen only .
When I checked partition table it shows only 68 GB.
Scandisk cannot resolving my problem .Please..................navigate me.
cnaren29 is offline
Old 08-04-2007, 11:05 AM   #2 (permalink)
Default Re: Hard disk fail's to load OS
Hey friend I can suggest something to you. The first thing is that don't use FDISK to partition your disk as it will not show you the exact space of your hdd. Second, try using winxp bootable cd partition manager. See the amount of space your drives are and then add all of the space it should be near 76000mb. Partition your hdd using xp partition manager. Then install your winxp. Also pls post ur result here.
abhijangda is offline
which hard disk to buy? tango_cash QnA (read only) 2 18-11-2006 03:57 PM
XP on USB Hard Disk sachin_kothari Hardware Q&A 3 31-10-2006 10:41 PM
compaq deskpro ep/sb series not detecting hard disk disk aditya169 QnA (read only) 3 22-05-2005 07:14 PM
cant add second hard disk drvarunmehta QnA (read only) 5 10-03-2005 11:24 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
