friends i am doing C#. I want to know how to get or store data entered by the user in a text box.
suppose you store data entered by the user in one variable and then use that variable to display the message and the same text.
pls help
The secret of creativity is knowing how to hide your sources.
Albert Einstein
^^ Note that the command label1.text=a.toString() should be placed within event handler for textbox text change... On the other hand, you can also write for focus leaving the textbox...
