Old 07-04-2007, 12:53 PM   #1 (permalink)
ayush_chh's Avatar
Default hard drive autorun!!!!
frnds my hard drives hav become autorun.....when i double click on any of the drives they do not open(so i rt click and the open)....i hav found some files on my drives
autorun.inf
MS32DLL.dll.vbs
desktop.ini
i hav opened MS32DLL.dll.vbs in notepad and found some 'unhealthy' codes but i can make no changes since the file is read only neither can i delete these files......plz hlp...
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 07-04-2007, 01:53 PM   #2 (permalink)
Default Re: hard drive autorun!!!!
It is a virus problem... Reboot in safe mode and scan with antivirus with latest definitions..
Arun
sakumar79 is offline
Old 07-04-2007, 02:12 PM   #3 (permalink)
ayush_chh's Avatar
i hav latest update of avast .....i hav scanned my system but in vain..
Old 07-04-2007, 02:29 PM   #4 (permalink)
Phenom II X4 920 Owner
prateek_san's Avatar
get NOD32...it detected that crap in my system......my autorun.ini got corrupted by virus........
"A strong positive mental attitude will create more miracles than any wonder drug." - Patricia Neal
prateek_san is offline
Old 07-04-2007, 02:53 PM   #5 (permalink)
ayush_chh's Avatar
is it a freeware?....i just hav a dialup connection..its not possible for me to download a big file...
Old 07-04-2007, 03:01 PM   #6 (permalink)
autorun.inf
MS32DLL.dll.vbs
desktop.ini
boot in safe mode & then delete these 3 files or else put them in another folder & zip that folder ur problem should be solved, I had these on my USB disk & tahts how got rid of them.
ranjan2001 is offline
Old 07-04-2007, 03:37 PM   #7 (permalink)
Fresh Stock Since 2005
Simple Virus Problem!!
And this virus is an open source virus.
If you open MS32DLL.dll.vbs in notepad and i you can read VBScript, you have the source....
Anyways, you can remove it by doing the following:
>>Ctrl+Alt+Del to bring up the task manager and End all instances of wscript.exe, if exist... Also kill MS32DLL.dll.vbs if found..
>>Start>Run>CMD.exe and then type
del c:\MS32DLL.dll.vbs
del c:\autorun.inf
>>Repeat the above step for each and every drive you have got...
i.e.
del d:\MS32DLL.dll.vbs
del d:\autorun.inf
del e:\MS32DLL.dll.vbs
del e:\autorun.inf
and so on....
>>Now, open Start>Run>msconfig and under start-up, uncheck MS32DLL.dll.vbs or wsscript if found....
>>Now search your c:\windows for MS32DLL.dll.vbs. It is likely to be found in c:\windows\ or c:\windows\system32. Delete it.
>>Now, update your antivirus.... Avast should do fine.. Make sure the definitions are updated....
>>Also, your USB flashdrives may also be infected, so insert them only when antivirus is enabled...
If you insert your flash drive, you may get the virus again. If you do, follow the same steps again, with your flash drive inserted. Delete autorun and MS32DLL.dll.vbs files from your flash drive too....
Now reboot and virus should be gone...
http://www.khattam.info
khattam_ is offline
Old 07-04-2007, 03:53 PM   #8 (permalink)
ayush_chh's Avatar
thnx a lot khattam....
i'll try ur soln....
Old 07-04-2007, 04:20 PM   #9 (permalink)
Super Saiyan
Goten's Avatar
LOL.
Boy get an antivirus....Not AVAST.
LOL.
Peace~~~!
Goten is offline
Old 07-04-2007, 09:55 PM   #10 (permalink)
ayush_chh's Avatar
thanx a lot khattam.....ur soln worked...
Old 07-04-2007, 11:54 PM   #11 (permalink)
thetopcyborg's Avatar
Originally Posted by Goten
LOL.
LOL.
Peace~~~!
Avast is quite a capable and effective antivirus. It even gave me better results than Norton.
thetopcyborg is offline
Old 08-04-2007, 01:28 AM   #12 (permalink)
Tech.Masti's Avatar
ah, no norton please..... so resource hungry
Tech.Masti is offline
Old 08-04-2007, 01:40 AM   #13 (permalink)
SE><IE
Posts: n/a
@ayush_chh: Simply deleting the autorun.inf file would have solved the problem. And no it was not a virus problem.
Old 20-12-2007, 11:30 AM   #14 (permalink)
sorry to bring up this topic again
but i had been facing this problem for quite a while now
i have removed all the concerned files and registry entries...i cant find them anywhere now....but when i double click on the drive icon....i get an error message:-
"cannot find script file MS32DLL.dll.vbs"
HELP!!!!!!!!!!!!!
iammrcool is offline
Old 20-12-2007, 11:50 AM   #15 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
^^hav u deleted autorun files
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 20-12-2007, 01:58 PM   #16 (permalink)
nach p's Avatar
yup n virus ,trojan detection and heling capacity is also less compare 2 avg ,nod and otheres
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
nach p is offline
Old 21-12-2007, 02:13 PM   #17 (permalink)
yeah i have deleted all the files
Why hard disk drive as removable drive? Sheik Rasheed K Hardware Q&A 6 25-03-2007 10:01 AM
USB Drive - "Access Denied" in Explorer, but works through autorun. navraj Hardware Q&A 3 29-01-2007 05:08 PM
Make Thumb drive Autorun q3_abhi QnA (read only) 2 23-01-2006 09:20 PM
Hard Drive toooo hard for 815 Sonu Yadav QnA (read only) 20 16-06-2005 03:55 PM
Hard Drive! Optical or Magnetic Based Drive Stitch QnA (read only) 1 30-05-2005 11:14 PM
