i use a PC at office which is sometimes used by others as well. how do i know if someone has logged-in in my absence?
i can see the pages from "history" but havent figured out how to check who's logged in. also, if the details from "history" are deleted, is there anyway, i can check up which all files have been accessed?
regards
Soumyajit
You can also use a keylogger to see what is accessed...
Also, there is a registry entry that stores MRU lists for various extensions - I think it is HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\ComDlg32\OpenSaveMRU but you may have to log in to the corresponding user to find the file they have used...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
