Old 05-04-2007, 10:45 PM   #1 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
Smile How TO Block Website
Hi Frnds If I Want To Block Website Like Suppose I Want To Block A Site Like Orkut From My Home Computer How To Do It So
Please Tell
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 05-04-2007, 11:29 PM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: How TO Block Website
Its very easy via router. Explore ur router carefully! U have filters via which u can proceed and block any site!
mediator is offline
Old 05-04-2007, 11:36 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
add the sites to ur hosts file or to the internet resticted zone.
c my post here content filter
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 05-04-2007, 11:42 PM   #4 (permalink)
hey friend you can block site by ur firewall.
abhijangda is offline
Old 06-04-2007, 01:32 AM   #5 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
stick with the hosts file method. and make sure to make it 'read only'
chesss is offline
Old 06-04-2007, 03:09 PM   #6 (permalink)
deepak.krishnan's Avatar
Arrow Re: How TO Block Website
In case of Internet Explorer, do try this out:
-> Go to Tools and select Internet Options.
-> Then in the security Tab.
-> Select the "Restricted" sites button.
-> Then click the "sites" button.
-> There add the site which is to be restricted.
.dk
deepak.krishnan is offline
Old 06-04-2007, 04:51 PM   #7 (permalink)
Set the url to 127.0.0.1 in the hosts file... EDIT: Instructions for this are available at http://www.mvps.org/winhelp2002/hosts.htm
Note that setting a site as restricted in IE will not help if someone tries to access via Firefox/Opera (which are now available as portable versions)...
Arun
sakumar79 is offline
Old 07-04-2007, 12:48 PM   #8 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
firewall is the best TOOL ....... try it ...........
ax3 is offline
Old 10-04-2007, 05:22 AM   #9 (permalink)
Norms Buster
And if I include all the websites that I wanted to block into the Windows Host file, will it work irrespective of whether I use IE/Firefox/Opera ?
Note :I'm not asking about restricting the sites on a specific browser.
VexByte is offline
Old 10-04-2007, 05:26 AM   #10 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Browsers have inbuilt custom blocking for sites just play a bit with the options.U r a geek u'll get it.
Harvik780 is offline
Old 10-04-2007, 07:31 AM   #11 (permalink)
I believe that it should work irrespective of the browser...
Arun
How to Block Ads in DAP ? 24online QnA (read only) 8 05-01-2007 12:18 AM
how to block a website prashantban QnA (read only) 8 21-10-2006 12:16 PM
How to block website using regedit dineshgaur1 QnA (read only) 7 17-04-2006 07:52 AM
How to block avtars __Virus__ QnA (read only) 3 30-10-2005 06:46 AM
want to block the properties. mylifevp QnA (read only) 4 28-12-2004 10:03 AM
