Old 05-04-2007, 08:37 PM   #1 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
Default Blog Problem.
I have a domain name (say) abc.tk and host the files at abc.275mb.com. Now i installed wordpress blog in the root directory. The root directory now contains index.html which has a link to the blog (index.php). The blog links works fine except in few places like:-
1) When i click for adding comments (after login) it takes me to 'Page doesn't exists' page.
2) On log-in page when i click on 'Back to XYZ's blog' it takes me to my site homepage (ie, index.html) whereas it should me back to my blog's homepage (ie, index.php).
Any ideas on why it's happening or how to correct it ?
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 05-04-2007, 09:59 PM   #2 (permalink)
eWebGuru
ahref's Avatar
Default Re: Blog Problem.
Instead of example domain, if you provide actual domain name and site address, then it will be easy to understand the problem.
BTW why you have both index.html and index.php in root, only php file should be there.
Windows and linux hosting at http://www.ewebguru.com
Get $50 per blog post PM me for details.
ahref is offline
Old 05-04-2007, 10:14 PM   #3 (permalink)
Ok. The site is hemant.tk and the host site is hemant.275mb.com. index.html is for my homepage which contains link to my blog.
So when i open hemant.tk i see my homepage from where i click on the blog link to get to my blog.
Both files are there because i want to have both the site and blog there.
Moving index.php to the blog folder creates problem.
Old 06-04-2007, 07:04 AM   #4 (permalink)
eWebGuru
ahref's Avatar
Better you keep your blog in differenet directory then root directory, as you have already have some content in root.
ahref is offline
Old 07-04-2007, 12:09 AM   #5 (permalink)
Re-installed the blog in different directory. Works without hitch if i go through hemant.275mb.com/blog. But if i goto hemant.tk and then clik on the blog link the problems re-appear:
I tried the following things with no success :-
1. Put blog link as : hemant.275mb.com/blog.
2. Put a blank page as blog.html and used javascript to redirect to hemant.275mb.com/blog.
Still i am having the said problems.
One more thing which i noticed is that whatever link i follow through hemant.tk has the adrress as hemant.tk in address bar. For eg: If i put a link to google.com on my homepage and click on it .. the google page opens up but adrress bar still shows hemant.tk. Is it the cause of the problem ??
Old 07-04-2007, 05:39 PM   #6 (permalink)
eWebGuru
ahref's Avatar
.tk keeps all pages in frames, this may be the cause of problem, use framebuster in your blog that may solve problem, also when I visited hemant.tk, it first take me to intermediate page, after clicking a link I went to your home page. Better you use .co.nr or some other service.
ahref is offline
Old 07-04-2007, 06:44 PM   #7 (permalink)
Strange never noticed that. Opera takes me directly to my homepage but IE takes to an intermediate page.
I'll try framebuster on blog and if that doesn't works i'll change domain.
Thanx for the help.
Old 07-04-2007, 07:16 PM   #8 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Almost evrywhere i see Page not found errors
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 07-04-2007, 09:16 PM   #9 (permalink)
Where ?? If it's on blog then that's what my problem is. If not then please specify what link you are clicking on?
@ahref : Framebuster didn't help. If i dont find any other alternative by tommorow i'll leave this domain.
Old 08-04-2007, 09:49 PM   #10 (permalink)
Problem solved. Turned out that a wrong .htaccess was culprit. As soon I removed that problems were solved. Still you can check out if any bad links remain in the blog.
Thanx to ahref for all the help.
Problem with blog columns champ_rock QnA (read only) 6 31-07-2006 10:26 PM
problem with blog champ_rock QnA (read only) 16 26-03-2006 10:27 AM
Wordpress Blog Problem navjotjsingh Software Q&A 14 19-06-2005 09:04 AM
