Old 02-04-2007, 07:20 PM   #1 (permalink)
Default Triband Speed Down Frm 2 Mbps To 256 Kbps Help Needed
i m using triband DSL NU i m getting speed 1.78 Mbps (bandwith) bt n m loosn my speed to 235kbs what the reason behind thi gyz plz help me i m usin D-LINK 502-T.
agasti is offline
Old 02-04-2007, 07:27 PM   #2 (permalink)
Default Re: Triband Speed Down Frm 2 Mbps To 256 Kbps Help Needed
maybe line problem or high loads on server
varunprabhakar is offline
Old 02-04-2007, 07:34 PM   #3 (permalink)
dattebayo
anispace's Avatar
thats becoz 2mbps is not available for unlimited plans including DSL-NU590.
u were lucky to receive those speeds for so long.
Yoda: No. Try not. Do... or do not. There is no try.
anispace is offline
Old 02-04-2007, 07:44 PM   #4 (permalink)
but my neighbour using DSL-NU and still he is getting 2Mbps speed
agasti is offline
Old 04-04-2007, 01:33 PM   #5 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
check ur Tline from MTNL ppl 4 any breakup`s ............. if yes then get it changed ........
ax3 is offline
Old 05-04-2007, 11:46 AM   #6 (permalink)
i already changed the wire now there is single connection direct to router.
if there a UL/DL ratio problem??
agasti is offline
is 7-8 kbps max speed of limewire downlod????(for a 64 kbps connection) tango_cash Software Q&A 23 12-07-2006 10:41 PM
only 10 MBPS max speed out of 10/100 MBPS NIC???? taken Hardware Q&A 9 01-03-2006 05:42 PM
256 kbps conx speed? legolas QnA (read only) 15 24-06-2005 09:12 AM
i m getting only 10 kbps speed iinfi Open Source 2 18-01-2005 05:19 PM
- by Krow
