Old 01-04-2007, 06:21 PM   #1 (permalink)
Default Zone Alarm Alarming!!!!
i've norton internet security 06, after i've installed Zone alarm so, it makes my lappy hanged for 10 sec appx.. and when i wanted to uninstall it, suddenly a windows error occured and my lappy was restarted now what shoould I do to uninstall it, its Pro licensed version..
I\'m the game & want to play
salils is offline
Old 01-04-2007, 06:30 PM   #2 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Re: Zone Alarm Alarming!!!!
Norton Internet Security (NIS) has its OWN Firewall, so its a big conflict going on in your laptop.
so disable NIS's firewall if you want to use ZAP.
but NIS is a very HEAVY on RAM & ZAP (v7) also takes up considerale amount of RAM (30+), so you're only making your lappy Slow.
either remove NIS or ZAP.
IMO un-install NIS & install "Active Virus Shield" or KAV & use it with ZAP.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 01-04-2007, 06:33 PM   #3 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Kick out that Norton... grow outta Norton... it sucks.. whatever-the-hell it does to lose weight... Get a free AV.. or if u really wanna spend money... check out Kapersky
koolbluez is offline
Old 01-04-2007, 06:46 PM   #4 (permalink)
the problem is that ZAF is not gettin uninstalled?????
salils is offline
Old 01-04-2007, 07:00 PM   #5 (permalink)
Why not restore XP to a point just before its installation of the offending programme?
V.Prem Kumar
janitha is offline
Old 01-04-2007, 07:04 PM   #6 (permalink)
Kiran.dks's Avatar
I am sure that Norton Firewall has clashed with Zome Alarm Pro Firewall causing system instability. First try uninstalling Norton.
Kiran Kumar R
Kiran.dks is offline
Old 01-04-2007, 07:40 PM   #7 (permalink)
i've uninstalled norton still using sys restore or all other way it's not uninstalling.......
salils is offline
Old 01-04-2007, 07:46 PM   #8 (permalink)
a_g = JPKN
s18000rpm's Avatar
run its installer again & then un-install it (removing not needed though)
Old 01-04-2007, 08:31 PM   #9 (permalink)
Chillum Baba
a_medico's Avatar
Boot in safe mode (F2 or F8..either of the two..not sure ).
Uninstall ZA.
a_medico is offline
Old 01-04-2007, 09:28 PM   #10 (permalink)
Distinguished Member
anandk's Avatar
going into safe mode will NOT allow norton to uninstall itself. use the 'norton removal tool' in normal mode if u decide to uninstall norton. my nis 2007 uninstall went really smoothly with this tool.
if u choose to uninstall za, u may do so in safe mode.
btw just wanted to share that the latest ZA7 fw seems to be having some compatibility probls with avast av. so avast users better hold for some time b4 upgrading their za fw
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 01-04-2007, 10:23 PM   #11 (permalink)
thanx guys in safe mode prob is solved..
salils is offline
Old 01-04-2007, 10:46 PM   #12 (permalink)
anandk wrote-
"btw just wanted to share that the latest ZA7 fw seems to be having some compatibility probls with avast av. so avast users better hold for some time b4 upgrading their za fw"
In fact, I had faced the compatibility problem with ZA & Avast and posted it in the forum several months back. Since then I have been using AVG.
V.Prem Kumar
janitha is offline
Old 02-04-2007, 06:58 AM   #13 (permalink)
Kiran.dks's Avatar
I have no problems at all. That's becoz I have disabled all the real-time scanners except "standard scanner" in avast! Antivirus. Activating other shields always has some compatibility issues with Zone Alarm Firewall.
Kiran Kumar R
Zone Alarm godsownman QnA (read only) 21 08-10-2005 10:50 PM
xp,zone alarm or me? mariner Software Q&A 12 08-09-2005 01:59 PM
Zone Alarm! cancer10 QnA (read only) 20 17-07-2005 01:55 PM
Zone Alarm pro help ! ! ! ax3 QnA (read only) 4 08-04-2005 11:28 AM
Zone alarm rahulbpatil QnA (read only) 3 08-09-2004 03:58 PM
- by Krow
