wht cr@p
the minimum system requirements for the game is :
System Requirements
Intel Pentium IV 1.3ghz (or AMD Athlon XP equivalent); Windows 98SE/2000/XP (95/NT not supported); 256 MB System RAM; 32 MB 100% DirectX 9.x compatible 3D graphics cards; 100% DirectX 9.x compatible-Compatible Sound Card; Quad Speed (4X) CD-ROM drive; 2GB free disk space; 100% Windows 98SE/2000/XP compatible mouse and keyboard
the game shld run on ur system
make sure u have the latest drivers,
vb run times, direct x 9 and stuff
if its a patched/scracked copy of the game
try downloading a different game exe file
tht surely helps coz these kinda errors happen due to that
otherwise if u really wanna play the game reinstall windows xp and update everything and then run the game
