Old 01-04-2007, 03:57 PM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default Set Default action
as in xp under file types u had the option of changing the default action on double click ... how do do that in vista
what i want:
*.Mp3 plays in winamp by default i want it to enque in winamp
any1??????
http://beingmanan.com
iMav is offline
Old 01-04-2007, 05:54 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
Default Re: Set Default action
rtclick on the file; open with; u get a dialog box; click on other programs 'arrow'; u get a set of programs which can open it; select the one u want; select always use this...; ok.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 01-04-2007, 06:00 PM   #3 (permalink)
iMav's Avatar
arre that will only set winamp as the default player and not change the default action ...
il explain in more detail:
right click on a mp3 file and u get:
play in winamp (highlighted as it is the default action)
enque in winamp (i want to set this as the default action)
iMav is offline
Old 01-04-2007, 06:19 PM   #4 (permalink)
anandk's Avatar
oh ! i m sorry. i dont use winamp if u dont get an answer here u cud always try http://forums.winamp.com/
Microsoft® MVP
anandk is offline
Old 02-04-2007, 12:22 AM   #5 (permalink)
iMav's Avatar
can ne 1 tell me how do i change the default action of a file in vista
iMav is offline
Old 02-04-2007, 02:04 PM   #6 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Open Winamp, goto "Options -> Preferences".
Goto "General Preferences -> Filetypes".
Now enable the option "Enqueue the files on double-click in windows explorer".
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 02-04-2007, 04:20 PM   #7 (permalink)
iMav's Avatar
thanx didnt see it there i thought its the same way in vista as it was in xp and 98
iMav is offline
Default action is now Search instead of OPEN (winXP) Ricky Software Q&A 1 09-12-2005 12:19 PM
Stealth Action Re-redefined(Credits added) pranjal_halo2freak Gamerz 1 13-04-2005 10:51 PM
Nvidia SLI in action !!!!! darklord Graphic cards 3 06-01-2005 01:17 AM
- by Krow
