Old 31-03-2007, 02:51 PM   #1 (permalink)
Default Folder NAming
Please tell me that why cant we create a folder named CON anywhere in the Windows why is it so. Can we Create the Folder with this name If Yes then Tell me How.
Ankit Roy
me_ankitroy is offline
Old 31-03-2007, 03:21 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Folder NAming
Even prn and nul
i dont know how to
i tried searching
but no result
Tech Geek is offline
Old 31-03-2007, 03:24 PM   #3 (permalink)
Beware of the innocent
ilugd's Avatar
con was reserved keyword in DOS. This has been raised in various threads. But don't worry. You won't be able to create a folder with that name.
Acually the Dos command copy con means copy to console and was a rudimentary text editor. You can try it out in the command console yourself. End the text entry with ctrl-z.
The syntax is
copy con <filename>
Life is too short. Have fun.
ilugd is offline
Old 31-03-2007, 03:29 PM   #4 (permalink)
MMO Addict
amitava82's Avatar
http://www.aldocabrera.com/2006/03/c...h-windows.html
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 31-03-2007, 03:36 PM   #5 (permalink)
Tech Geek's Avatar
http://geekswithblogs.net/aboos/arch.../19/57411.aspx
in the end of the page
Old 03-04-2007, 05:21 PM   #6 (permalink)
Type the following in command prompt
C:\> md \\.\c:\con
(Posted by Sridatta on that forum itself earlier!)
ThinkFree is offline
How to hide folder in windows XP without using folder guard sridatta Software Q&A 23 06-12-2006 06:32 AM
web folder ! ! ! ax3 QnA (read only) 6 08-09-2006 09:03 AM
PDF pages naming ? shreyadr Software Q&A 4 29-06-2006 08:32 PM
RAM naming confusion rahul_becks23 QnA (read only) 1 12-04-2005 01:37 AM
- by Krow
