hey you people;
Does anybody know any easy software which can easily convert Pagemaker to PDF files plz give the download link.
And how do those guys put document security on PDF acrobat files cant change them or sometimes cant even print them ; they have little "key" thing at bottom.????
Which version of Pagemaker are you using? There is a built-in PDF exporter in versions 6.5 & 7.
I suppose yours is a lower version. In such case, solution by swatkat or many others like pdf4free, pdfMachine, etc are available. Do a google search. See if they have security options.
