Old 30-03-2007, 09:48 AM   #1 (permalink)
pritish_kul2's Avatar
Default CAncelling Shutdown
Is there any way by which we can cancel the shutdown after clicking shutdown
pritish_kul2 is offline
Old 30-03-2007, 10:21 AM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: CAncelling Shutdown
Why would you want to do that in the first place ?
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 30-03-2007, 11:25 AM   #3 (permalink)
shashank4u's Avatar
i think not possible i think...
i use hibernation
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 30-03-2007, 11:51 AM   #4 (permalink)
MMO Addict
amitava82's Avatar
sometime it happens to me. thinking i don't have anything to do, i shutdown the pc then suddenly i remember i've forgotten some important task...
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 30-03-2007, 12:12 PM   #5 (permalink)
dd_wingrider's Avatar
Shutdown Can be stopped during those 10 seconds using SHUTDOWN -a
http://iphone3g-india.com - One stop for all iPhone3G updates, tips,news,resources
http://iPadarena.com - Teh iPad Blog
dd_wingrider is offline
Old 30-03-2007, 12:33 PM   #6 (permalink)
shotdown -a command only works when we are at desktop. Basically this command is used when any services fails and showning the message " Your system is shout down within xxx second". To stop uncertain shoudown we rune this command....
_____________________________________
bipshee1234 is offline
Old 30-03-2007, 05:08 PM   #7 (permalink)
i think you can use the command shutdown -c
try it!
Shankar Ganesh is a 16 year old Blogger & Freelance Writer from India. He writes at http://www.killertechtips.com. Gtalk ID - techgurushankar, Skype - shankarganesh91
shankar_ganesh is offline
Old 30-03-2007, 08:46 PM   #8 (permalink)
^^^^ means press c button after pressing shutdown/??
Old 30-03-2007, 08:58 PM   #9 (permalink)
Smile Re: CAncelling Shutdown
no, i meant this:
u've pressed the turnoff button in the shutdown dialog... your system is going down for a shut down. now if you wanna avert this use the command shutdown -c
you can use it easily by pressing WINKEY+R launching the RUN bar, and then typing shutdown -c,pressing enter
Windows SHUTDOWN Problem, system freezez on shutdown screen catch_maxi Software Q&A 2 16-03-2006 07:38 PM
"improper shutdown" msg on proper shutdown mvishnu QnA (read only) 2 26-02-2006 06:50 PM
NO SHUTDOWN! gary4gar Software Q&A 2 09-02-2006 02:03 PM
need for shutdown .....?? vijay_7287 QnA (read only) 3 19-11-2005 05:56 PM
- by Krow
