Old 30-03-2007, 12:55 AM   #1 (permalink)
Default how do i burn iso movie to dvd ?
i have some movies that in the iso there are 4 folders (i guess you know what i mean), how do i burn those ISO files to dvd-rom ?
how do i burn any kind of ISO files to dvd-rom? for regular cd i picked the option burn image but it doesnt work for dvd WHAT TO DO?
assddd is offline
Old 30-03-2007, 01:12 AM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: how do i burn iso movie to dvd ?
try this ... if u have nero ... there somewhere u will find an option for burning an image ... in that browse and select ur iso file to be burnt ... i think it shud the work
http://beingmanan.com
iMav is offline
Old 30-03-2007, 01:33 AM   #3 (permalink)
In search of light...
abhi.eternal's Avatar
Get Alcohol 120%. Play with image files!
http://abhijeetdeb.com
abhi.eternal is offline
Old 30-03-2007, 02:08 AM   #4 (permalink)
MMO Addict
amitava82's Avatar
if u wanna burn iso image as data disk then select 'data disk' as project type. if you want to make individual CDs select 'burn saved project' in nero.
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 31-03-2007, 02:32 AM   #5 (permalink)
i cant find that option "burn saved project"
all i want is to burn iso files to dvd.
for regular cd all i had to do is burn image option but it doesnt work for dvd disk.
assddd is offline
Old 31-03-2007, 03:05 AM   #6 (permalink)
iMav's Avatar
ok let me get u clear ... u have iso files of say about 800mb now u want these isos on a dvd??
iMav is offline
Old 02-04-2007, 01:32 AM   #7 (permalink)
"MKIN WAY 2 android"
Orionz's Avatar
Smile Re: how do i burn iso movie to dvd ?
Deficult to understand that what you are saying.
from which media you created iso image.
I suggest BlindWrite To uSe
Orionz is offline
Old 02-04-2007, 10:11 AM   #8 (permalink)
MMO Addict
amitava82's Avatar
Use PowerISO. go to Tools > Burn. Select Image file. Check the box says "DVD Disc" and burn. Thats all..
Burn dvd? shashank_digitreader Tutorials 9 22-03-2007 05:25 PM
HOW TO BURN A 2 CD MOVIE or GAME to 1 DVD caleb Software Q&A 11 24-09-2006 02:34 PM
how to burn a .avi movie readermaniax QnA (read only) 4 05-06-2006 07:51 PM
HOW TO BURN A DVD tango_cash QnA (read only) 2 23-06-2005 10:27 PM
I need a movie player that can paly NFS movie files(.mad ) dcp15121980 QnA (read only) 28 15-01-2005 12:27 AM
- by Krow
