rollcage:
virtual dub can convert to evry format you want, you just need the conversion codecs for that format installed on your system
and yes alib is correct, in vcds dat file are mpg encoded with just some extra information added into them
divx compromises very little on quality but really decreases the size
\"I was born INTELLIGENT
But EDUCATION ruined me!!!!\"
AMD 64 3200+(Winchester), MSI RS480M2-IL, 512*2 DDR400 Hynix, Segate 80 GB SATA, LG E700SH, i-benz with Intex PS (400 W)
