Originally Posted by adorablesrini
What can be the Maximum Temp for Hard Disk? My hard disks Temp goes on til 27degrees C.
Depends on the drive. I had a 500 meg/7200RPM Maxtor drive which you could not touch after it ran for 30 minutes. Even the other Maxtor's 60/80 gig Maxtor's 5200 RPM drives get very hot but you can pick it up without getting blisters. But the samsung 160's although running at 7200 is much much cooler than the Maxtor's. Oh yea the old Maxtor's 7200 drives I don't think you can run in India. I had a 27gig 7200 rpm drive that has stiction problems. This is when the drive runs so hot that the oil changes composition and then when the drive cools down, it turns into glue and sticks the head. I thought since the drive was not as hot as the 500 meg one which you could not touch it might be okay... Guess not..
