HEY ITS COOL BUT IT WOULD BE NICE IF IT SAVES THE KARAOKE ALSO
SO IF ANY ONE HAS A SOFTWARE LIKE KARAOKE ANTHING AND IT SAVES ALSO THEN PLEASE SUGGEST ME?????
Download AnalogX Vocal remover from www.analogx.com ,Its Free.
There are two softwares on this site.One is a winamp plugin and other one is a directX plugin which works with all good audio editors like Nero Wave Editor.
The AnalogX Vocal Remover Direct X plugin works with all audio editing tools (Popula) like nero wave editor etc.U can add vocal remove as an effect from under the effecrs column.
Anyways use the winamps Wave output function to record.
VirtualDub is very cofusing. Use VCDCutter from Jiao Systems. It can cut clips from large movie files, separate them to voice and video file, and join various clips of VCDs and many more. Just try it file size is also not too big to downlaod.
