Old 27-03-2007, 06:09 PM   #1 (permalink)
Default "DISKPART" created probelom for me help plssss
hello everybody,
i have a PC with intel pentium D820,Samsung 80GB sata HDD ,and have WIN XPSP2 installed on it .
i am not a verry intellegnet PC user so one day i was just trying DISKPART command in command prompt (i want to tell u i have four partitions in my HDD C,D,E,F in which C is the system disk)
Accindentelly i marked the partition E as ACTIVE (the part was empty) .And after that when ever i starts my pc it is not starting it shows the system setup screnn after that it prompts me something like this===
PLEASE RESTART THE COMPUTER AND SELECT A PROPER BOOT DEVICE
OR INSERT THE BOTT DISK IT THE DRIVE AND PRESS ENTER
i tried to biit from A MSDOS start up floppy disk but probelom was still not solved please help me what shoul i do pleaseplease
thank you all
priya_2006 is offline
Old 27-03-2007, 06:13 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: "DISKPART" created probelom for me help plssss
U can do following 2 things:
1. Boot using XP Setup CD and enter into Recovery Console and then u can again run "diskpart" and can set C: as active.
2. Boot using 98 Setup CD or DOS bootable floppy and then run "fdisk" and then u can set the C: partition as active.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
"Search" is the first option instead of "Open" Rooney Software Q&A 4 31-01-2007 01:28 PM
hiding the "download" status "dialog box" keves2002 Internet & WWW 19 08-09-2006 12:28 AM
"INF Error", VGA Driver "Missing" Installing ATI Catalyst Drivers CannedLizard Hardware Q&A 4 29-07-2006 12:47 AM
- by Krow
